Low volt at idle xj700 aircooled
Discussion in 'XJ Technical Chat' started by Stroker, Jul 18, 2021.
  1. Stroker
    Stroker New Member
    Norway
    Hi. Just found that my 85 xj700 aircooled bike do not charge battery at idle, but the volt comes when the rpm increases to approx 2000rpm. Anyone know what can be done to fix? Or is it normal....
  2. Franz
    That is normal I believe.
  3. Mechanic1978
    Mechanic1978 Active Member
    NOYB
    yes this is normal....
  4. Stroker
    Stroker New Member
    Norway
    Ok. Thank you all
  5. XJ550H
  6. Rooster53
    Some numbers would help to be sure. At approximately 2000 RPM and above the battery voltage should be 14.5 VDC +/- .3 V with a fully charged battery.
