Maxim 650 Starting Problems
Discussion in 'XJ Technical Chat' started by frenchtracker, Feb 22, 2015.
  1. frenchtracker
    frenchtracker Member
    vancouver
    starting to lose my mind over this
    have a 1982 maxim 650
    the bike started fine until i changed the bars.. something with the starter button its not doing anything when i push it
    I play around with the 2 red/white stripe wires and i hear clicking in the relay
    battery died so i charged it with a car bat. charger @ trickle charge .. not sure if that has anything to do with it.. but there is power the signal and horn works
    Any tips on what i should check?
    thanks in advance
  2. FtUp
    FtUp Well-Known Member
    pacific northwest
    do you still have the oem (glass tube fuses) fuse box? the connectors get brittle and crack causing a poor connection. that's where I would start looking.
    FU
  3. k-moe
    Are the new bars painted? IIRC the ground for the controls are through the bars on that bike
    frenchtracker likes this.
  4. frenchtracker
    vancouver
    I believe it's all hard wired
  5. frenchtracker
    vancouver
    This sounds more like it yeah they are painted..
    so the control box makes the ground on the bars?
    I'll try that out thank you!
  6. frenchtracker
    vancouver
    no dice..
  7. FtUp
    pacific northwest
    I am talking about the connectors the fuses pop into, not the wiring connectors.
    FU
  8. Rooster53
    If you can believe the Haynes Workshop Manual the XJ650H (1981) uses the bars as a ground for the starter switch. Since you have an 82 (XJ650J), then there should be a separate black wire providing the ground for the starter switch.
    The two red/white wires are for the kill switch. It must be functional and providing 12v to the starter cutoff relay or the start button is not going to do anything.
    Checking the fuses is a great idea - hopefully hardwired doesn't mean some PO took them out.
    The horn, signals are on a different circuit (signal), so they can work and the starter still not engage. The starter circuit is part of the ignition circuit, so that one fuse powers the starter cutoff relay, the starter solenoid coil, and the TCI and Ignition Coils.
  9. hogfiddles
    I'd go for a new battery.....
  10. Koxevicius
    Koxevicius Member
    Norway
    I am pretty sure that this is the problem. I had same problem.
  11. frenchtracker
    vancouver
    My bad it is a 81.. I sanded off the paint it's now raw metal still isn't working. .
    It must be the switch that just gave up out of no where?
    You don't think the relay could have gone?
  12. frenchtracker
    vancouver
    But it powers up the signal horn circuit...
  13. frenchtracker
    vancouver
    There are no fuses or fuse box
  14. hogfiddles
    Doesn't take much to blow the horn.....
    If you have no fuses or fuse box, you're sitting on a time bomb
    jayrodoh likes this.
  15. jayrodoh
    jayrodoh YimYam
    Cleveland
    Agreed, ever seen how fast and hot a wiring harness goes up with the amperage a battery puts out? I lost the factory harness in my 65 Scout (no fuses from factory), destroyed many components behind the dash. No way you'd catch me sitting on that with those fuel lines nearby.
  16. frenchtracker
    vancouver
    why would someone rip it out i don't get it.. bike looked stocked..
    is it hard to put in a fuse box? what wires would i lead to it?
  17. frenchtracker
    vancouver
    UPDATE
    I was screwing around with it.. jumped the solenoid and it started up.. or tried too at least
    i was testing the 2 red wires with white stripes in the starter switch and i went to test the blue button wire and she's started working!
    But the blue wire had a bit of loose wires coming out from me messing with it that i would touch metal and turn over
    so i cut it.. re soldered it.. nothing
    Wtf!
    Still jumps on solenoid..
    took the plastic out where the 2 red wires sit.. cleaned the switch terminals.. nothing
    Any ideas??
  18. jayrodoh
    jayrodoh YimYam
    Cleveland
    82 had the glass fuse style box under seat. The clips would eventually weaken and the fuses wouldn't make a good contact, which in turn caused issues. If you search on here, there are great threads on upgrading. There will probably be 8 wires somewhere on the right side under the seat that were cut and patched together if the box was removed (4 sets of two patched together).
  19. Rooster53
    So there should be a blue/white wire as the input to the starter switch, and since you have the 1981 version the current path for the starter solenoid coil is through the starter switch to the handlebars, which would then connect back to frame ground completing the path. You can't just have a connection at the control, the bars must also electrically connect to the frame through the mounting hardware. If you are touching the blue/white wire to ground and the starter is engaging, then the starter switch or path to ground for the switch is defective.
  20. Rooster53
  21. frenchtracker
    vancouver
    Thanks for that how to thread!!
    So you're saying that the whole bar would have to be bare metal for the current to go through mounting hardware??
    I don't understand why it momentarily worked though...
  22. frenchtracker
    vancouver
    The only wires I can think of that had fuses are the rear brake light and signal lights... everything else looks stock.. is
    What are the main things that have to be fused?
  23. hogfiddles
    MAIN
    HEADLIGHT
    TURN SIGNALS
    IGNITION
  24. Koxevicius
    Koxevicius Member
    Norway
    Just take apart the thing where starter button is. Then take a wire attached it to the negative point of the starter button and other end of the wire straight to the frame (ground point). See what happens
  25. frenchtracker
    vancouver
    It works! Now what haha
    I just put the wire to the frame and it turned over..
    It must be a ground problem.. I don't understand though
  26. jayrodoh
    jayrodoh YimYam
    Cleveland
    He's not saying that the paint has to be removed from the bar totally, just where the switch housing contacts the bars AND where the bars contact the tree at the clamps. You must have electrical continuity from electrical ground (frame) to the switch housing. If you have a multimeter, they usually have a continuity or at least a resistance setting. You want as close to 0 ohms as possible between them.
  27. frenchtracker
    vancouver
    OK.. sorrg this is all new to me.. so I have to check what again for resistance? Where do I put my pos and negative to check?
    I think my problem is that I didn't sand down paint at the trees or clamps..
    Also the bars I bought don't fit tightly or flat .. It is the right size (7/8)
    I hope that won't be an issue for grounding
    If all fails can I just run a wire to frame from switch?
  28. jayrodoh
    jayrodoh YimYam
    Cleveland
    Put one lead on the frame or battery neg. The other on the bare metal part of the handlebar where the controls clamp on. You should see close to 0 ohms or if you have continuity check, it will beep/light/move the needle (depends on meter).
    Yes if you didn't clean up the clamps/bars, I would start there.
    You can run a wire if you desire, they did that later year models. Better design then relying on metal to metal contact through a few pieces.
  29. hogfiddles
    Yeah.... Use the later controls
    OR
    take a look at the connector at the end of the pigtail..... I bet you have an empty socket there. I also bet the the main harness has a ground wire there---- that allows you to wire in the ground, just slide some black heat shrink tubing over the wires after you have your ground wire put into the switch's harness
  30. Koxevicius
    Koxevicius Member
    Norway
    That's what I did. I just have nice wire running from the control unit to the trees.
  31. MattiThundrrr
    MattiThundrrr Not a guru
    America's friendly hat
    i think part 9 in that diagram is missing on my bike! is that cuz i gots an 82, or is it cuz i'm driving straight to hell?
  32. frenchtracker
    vancouver
    She's a runner! Thanks for the help dudes!! Cleaned up all the ground faces and it worked..
    Does anyone know any good threads on fuses?
    Could I just add those tubular fuses in between wires?
  33. frenchtracker
    vancouver
    just put it all back together.. put er on prime.. won't start up.. Perfect!!
    there is spark..anything i should check out? did something wrong somewhere
  34. Koxevicius
    Koxevicius Member
    Norway
    Damn.. Looks like the electrical part on these bikes are like women on her period and eating magic mushrooms.
    Try to check every part that was involved in the latest tests and work you did...
  35. jayrodoh
    jayrodoh YimYam
    Cleveland
    If it's got spark, check for fuel! Did the choke lever or cable get messed up with the handlebar swap?
  36. rocs82650
    rocs82650 Well-Known Member
    Middle Tennessee
    Depending on the manufactured date most '82s and later have a ground at the control and in the flashers. The 80, 81 and some 82s don't have this added wiring. The control and flashers are ground through the frame.
    Gary H.
