Maxim Engine question with picture included
Discussion in 'XJ Technical Chat' started by Yamaholic, Sep 3, 2013.
  1. Yamaholic
    Yamaholic New Member
    Michigan
    Hmmm I dont think this screw is supposed to be here.....I never noticed it until a few days ago.... Any suggestions on this freeze plug that has a screw drilled into its place. I dont know too much about this and I try to pull as much info as I can, but I cant find much.[​IMG]
  2. BruceB
    BruceB Active Member
    Isle of 8 Flags, Florida
    I just went out and looked at my 82 XJ650J Maxim and that screw does not exist on my bike. What size motor is on your bike?
  3. sektorgaz
    sektorgaz Member
    Western MA, United States
    Maybe our bikes are from different batches, but my 82 650J DOES have the pictured screw on the right side only.
  4. BruceB
    [​IMG][/url][/img]
    Hmmm...here is a pic of my plant....wonder of Rick, Fitz or Len knows why some do and some don't....
  5. bigfitz52
    Not WHY, but I know WHAT it is, or where it leads anyway. That "taps into" the oil feed to the intake camshaft. It's either there because of something done in production, or as a "vent" to ensure oil flow after an oil change. If it were for the latter purpose, you'd think it would be mentioned in an owners' manual somewhere but it's not that I know of.
    The XS400 twin manuals DO mention it in regard to post- oil change (opening it until oil pukes out.)
    My '83 550 has one, my '81 550 is just "blank" and I'll have to look at the 650 when I get home.
  6. Yamaholic
    Michigan
    I have the MAxim with the 750 in it, :/ I just am really shocked I didn't see this....I really just Sorta mind blown, I've looked at quiet a few pictures on google/bing with out finding any with it, saw nothing in the manual..Feeling a bit worried about this, I haven't noticed any oil or fluids leaking out from the head of the screw. Thanks for the answer again bigfit...Your the man no joke...I got this feelin deep inside you could take 1 XJ apart and construct 5 out of it
  7. zombiehouse
    zombiehouse Member
    Pomona, Ca
    My 82 550 Seca has it but neither of my 81 models have it.
  8. fiveofakind
    fiveofakind Well-Known Member
    San Diego, CA
    pic of my '82 XJ750J Maxim.....no bolts
  9. bigfitz52
    I checked my 650 (pre-YICS motor) and it doesn't have one.
    There should be no cause for concern; and I've never had an oil feed problem after an oil change.
    Looks like it "phased in" on the YICS motors at different times for different models; again, exactly why remains a bit of a mystery.
  10. bendoza
    bendoza Member
    portland, or
    my 83 xj750mk has that screw on the right side of the engine. just like yours.
  11. adrian1
    adrian1 Active Member
  12. jmilliken
    jmilliken Well-Known Member
    Dillsburg, PA
    my 85 and 86 700 have it...
  13. RickCoMatic
    That Fastener Plugs the Top-ends Oil Gallery.
    The others had Blind Plugs pressed-in.
    This Port serves to provide a convenient spot to attach an Oil Pressure Gauge for evaluating the Plant's pressure.
    Also, as dumb place for Oil Pressure Gauge's to be mounted and a very inconvenient spot from which to mount plumbing or a sensor.
  14. quebecois59
    My '83 Seca 900 has one on the right side of the engine only.
  15. bigfitz52
    That's all there is if you have one.
    I have a theory if anyone wants to hear it:
    Back in the day, Yamaha had been getting customer complaints about "ticking" sounds from the top end, especially if a bike had been parked, hot, on the sidestand. This is evidenced in Yamaha tech bulletins from '81 that eventually led to a revised cam cap to tighten up the inherent sideplay in the cams.
    My theory is that Yamaha introduced the un-plugged drillway so that they could ensure proper top-end oiling on the bikes before they left the factory; or so that dealers could confirm proper oil flow to the cams.
    Which is a complete SWAG.
  16. sektorgaz
    sektorgaz Member
    Satisfied Women Aging Gracefully?
