Maxim x clutch
Discussion in 'XJ Technical Chat' started by MikeT, Mar 22, 2011.
  1. MikeT
    MikeT Member
    Newfoundland, Canada
    I am going to replace the clutch on my maxim x and am wondering if the clutch components on an airhead 700 is the same for the maxim x. I have seen a couple kits listed for both bikes but only springs listed for the airhead 700. Anybody know if they are interchangeable?? Thanks.
    Mike
  2. bigfitz52
    Questionable. They have different part numbers in the fiche; and neither cross-reference to any other bikes like the friction plates do.
    Chacal's listing is only for "Non-X models" so there must be some difference.
    I recommend you drop chacal a PM and see what he can tell you.
  3. MikeT
    MikeT Member
    Yeah thanks for the reply, better to go with chacal then at least you know the parts will fit. Once I get into it then I'll have a better idea of what is what and maybe see if there are any differences. Thanks again.
    Mike
  4. mcrwt644
    mcrwt644 Member
    Winchester, VA
    I don't know if they are the same or not. I believe the x model would have higher tensioned clutch springs and probably beefier plates due to the fact it is a higher hp engine.
    The x and airhead have a number different part numbers, but many x reference and are usable. Case in point is my ex has a full air head exhaust on it and it has a different part number.
    But as far as internal engine parts are concerned, I'm sticking with the correct part #'s.
  5. MikeT
    MikeT Member
    Yeah got an e-mail form chacal with a background and the differences in the bikes. Pretty interesting actually. Going with parts from him I think at least they will be correct. Good to know that the airhead exhaust will fit the X too. Any mods that need to be done or is it a direct bolt on? Has to be the same if it fits with no issues.
  6. mcrwt644
    mcrwt644 Member
    Winchester, VA
    The airhead and x exhaust minus the part numbers, are precisely the same in every way. Putting the exhaust on an airhead is muuuuuch easier and requires much less name calling than the x due to the radiator....If you have to do fork seals....pull the entire front end and do the exhaust at the same time...THAT is EASY IMO.
