maxim x front end on turbo maxim 650
Discussion in 'XJ Modifications' started by farmer, Nov 4, 2012.
  1. farmer
    farmer Member
    HI guys,
    For my turbo build I installed the maxim x forks and triple tree to get slightly bigger forks as well as the better fork brace setup. As well as the dual disk front. Requires a washer/spacer at the bottom of the triple tree stem or else it bottoms out on the tube.
    Anyways, see the pics, am i missing anything? The order of assembly is the dust cover, then the 2 nuts, then the top triple tree and nut correct? Don't see any other way it could go but wanted to be sure...
    Thanks!
    Chris
  2. MiGhost
    MiGhost Well-Known Member
    You are missing a couple pieces. Both still available through yamaha.
    Between the two nuts.
    Yamaha WASHER, PLATE, 90202-26142-00
    Between the top nut, and top crown.
    Yamaha WASHER, SPECIAL, 26H-23418-01-00
    This will have tabs that slide down into the grooves on the nuts to keep them locked together.
    Ghost
