Maxim X wiring question
Discussion in 'XJ Technical Chat' started by tumbleweed_biff, Apr 19, 2012.
  1. tumbleweed_biff
    tumbleweed_biff Active Member
    Gahanna Ohio
    Hi,
    There are three white wires in a bundle coming from under the engine and then up to the wiring harness. All three wires are white and they are wrapped with what seems to be a cloth wrapping. From what I have figured out, I believe that these are from the generator and run to the regulator. On the wiring harness I have a nice modular plug. The PO had done a hack and slash so I have bare wires with no connector on the cable underneath. Does it matter which wire connects to which? They all appear to be identical.
  2. greg_in_london
    greg_in_london Member
    London
    No, it doesn't matter. the regulator/rectifier will hand the signal from them whichever way you wire the three and magically turn it into 12v DC.
