maybe found great deal! Need help diagnosing tranny issue?
Discussion in 'XJ Technical Chat' started by prince_albert3, Jan 31, 2012.
  1. prince_albert3
    prince_albert3 Member
    Rochester, PA
    Ok, I might be a little over excited about this one...!
    Seller claims the bike runs great. It does look great! BUT... it is stuck in first gear. Says he rode it one day, no problems, then parked it and it has been stuck in first gear ever since...
    Please, any thoughts. Maybe what it would cost for new tranny or any silly hickups.
    I'd hate to miss this deal. I'm gonna go prepare the misses for the new addition. I'll check back... thanks
  2. wingnut325
    wingnut325 Member
    Havelock North Carolina
    The XJ 750 did that once. Seem to remember folks saying parts from the chain guide break off and jam the shifter. We changed the oil & filter and never had the issue again.
  3. prince_albert3
    Rochester, PA
    Thanks. I'd love it to be that easy!
    Keeps 'em comming guys. I've got the wife to "see if you can get a better deal
  4. FJ111200
    FJ111200 Active Member
    Crewe, Cheshire, England
    Re: maybe found great deal! Need help diagnosing tranny issu
    My XJ900, early model, did that once.
    Turned out to be the spring on the shift shaft was jammed.
  5. prince_albert3
    Rochester, PA
    Right on.
    I just searched it and read the 2 pages of thread listings.
    Cam chain guide or shift mech....
  6. bigfitz52
    PRIMARY chain guide starting to break up, if it's a 650/750/900;
    the 550s don't have that problem.
    ANY model-- it could be as simple as a broken spring in the shift mechanism "mousetrap."
  7. tcoop
    tcoop Active Member
    South Weber, Utah
    Had that happen on two XJ750's ... It was the Primary Chain guide braking up. If that's the problem you would need to split the case to fix it.
  8. trgrhappy
    trgrhappy Member
    Post Falls ID
    My 550 was as simple as the screw holding the segment onto the shift drum was busted
  9. mtnbikecrazy55
    How much is the seller asking?
  10. prince_albert3
    Rochester, PA
    I was at the hospital in the waiting room when I posted this earlier, had to be quick...
    Anyway, what would be a good general cost estimate for splitting the case? oil, gaskets, orings, sealers, primary chain guide...all things considered?
    I'm looking for some bargaining leverage here....
    thanks again guys
  11. Polock
    depends on how the gaskets come off, for those, 4 of them i think.
    15 or 20 for the guide (chacal) torx bit, impact driver, some locktite and yamabond.
    more labor than money
  12. Polock
    oh, tell him the swingarm has to come off to get the engine back in, because it really is easier that way but not necessary
  13. hogfiddles
    drain the oil, take the left engine side cover/shift pedal off. You should be able to see in there to carefully remove main chain guide pieces if you're careful. Saves having to split the case at the moment. Get the pieces out of the way and you should be able to shift.
    For more detail on that, get the xjcd and read the section on "Emergency Roadside Guidectomy".
    Now, if the shifter forks are bent, that's a different story.
    Dave
  14. bigfitz52
    for "bargaining power" explain to him that splitting the cases to replace the chain guide will cost well more than the bike is worth, and he should be paying YOU to take it away.
  15. prince_albert3
    Rochester, PA
    The job may very well be more work than value reward. He should probably pay me...
    If I invest less than the value of the parts I can pull off, and I am, as well as gain some insight, I'm in!
    http://xjbikes.com/Forums/viewtopic/t=35498.html
