Melted wire... Should I worry?
Discussion in 'XJ Technical Chat' started by apato632, May 22, 2016.
  1. apato632
    apato632 Member
    Millarville, Alberta, Canada (near Calgary)
    Hi all,
    I searched the forums for this issue but I couldn't find it so I thought I'd pose it to the group. This is for an XJ650RJ.
    I removed the electrical connection for the rectifier to find melted plastic near the red wire. It was fused together quite tightly. There are no electrical problems with the bike but I am concerned that some could develop if the issue gets worse. The only electrical issue I've noticed is that the headlight dims slightly when the bike is at idle. In my experience that is normal.
    My questions are, how does the connection melt, should I be worried, and how can I fix/prevent this?
    Thank you,
    Aaron.
  2. Jetfixer
    The recifier gets hot , a 30 year old bike probably not to bad from picture. Clean up plug reconnect see if battery is being charged, put a volt meter and check voltage before you start and after start , 12 v before and 13v running.
  3. hogfiddles
    Should you be worried? No
    Should you do something about it? Yes
    TheCrazyGnat likes this.
  4. Mustang
    Mustang Member
    Masonville
    Exact thing happened to mine, going to replace the connection with a weatherpack
  5. XJ550H
    whats a weather pack
  6. ant797
    ant797 Member
    western australia
    melting wires can happen when theres a bad earth somewhere
  7. jmilliken
    jmilliken Well-Known Member
    Dillsburg, PA
    You have resistance somewhere
  8. Saltydog
    Saltydog Member
    Eastern NC
    I get "resistance" from the Wife all the time regarding my bike. How do I fix that?
    Crimson9mm, amiel1157 and Lightcs1776 like this.
  9. jmilliken
    Dillsburg, PA
    That requires an upgraded model
  10. jayrodoh
    jayrodoh YimYam
    Cleveland
    Upgraded water tight connectors. I used to use them for my custom harnesses . See them in automotive applications quite frequently.
    jmilliken likes this.
  11. XJ550H
    dirty connections and bad battery constantly calling for a charge.
    I see it is the red wire that melted. clean your ignition switch inside connections and external.
    Clean and lube the ignition switch
    if you have the room you could remove the red wires from VR connectors and give them a connector of their own. clean all your headlight connections and the relay that controls the headlight.
    it is the biggest current draw, then tail light connections as they are always on too.
    I went led for tail/brake light and lic plate light
  12. Mustang
    Mustang Member
    Masonville
    I used to use these all the time working on semi tractors, there is a pliers for them but needle nose works too
