Mixture screw & YICS blocking tool
Discussion in 'XJ Technical Chat' started by zoutlaw, Sep 25, 2009.
  1. zoutlaw
    zoutlaw New Member
    I've been reading many post on the fuel air mixture screw adjustment on my 1982 XJ 750 and have not seen any one ask or address this. For best adjustment of the carbs to each cylinder is it best to have the tool installed or not? If so why or why not?
    Joe
  2. Bushy
    Bushy Active Member
    It is said to be best to use the tool, coz then you are adjusting individual carbs like when doing the synch' you are adjusting individual carbs, with the tool installed. Oh damn the can of worms got knocked over (debate likely to ensue)
  3. TIMEtoRIDE
    Hey ! Welcome Zoutlaw !!
    The answer to your question, according to my Magic "8" ball is- - No !
    Unless you are using a ColorTune or Exhaust gas analyzer,
    you do not use a YICS tool for any of the other techniques for adjusting the Pilot screws.
  4. Ass.Fault
    Ass.Fault Active Member
    College Station, Texas
    Negative, leave the yics chamber alone when adjusting and reading plugs.
    It has gotten me better results in the past
  5. Bushy
    Bushy Active Member
    I neglected to mention colourtune, sorry.
  6. Carvall
    Carvall Member
    Seattle
    One more question for everybody. When is the mixture gets richer when you turn in the screw or when you turn it out?
  7. Scholz
    Scholz Member
    Canada
    richer out l
    eaner in
  8. Carvall
    Carvall Member
    Seattle
    Scholz- Thanks for the answer but some think the opposite. Could you explain why?
  9. bigfitz52
    I would guess it's a misconception about what the mixture screws control, air or fuel (they control fuel.)
  10. yamahamaxim85
    yamahamaxim85 Member
    england
    how many turns out should they be, as i was going to buy the tool, as me carbs are all over the place, my gsxr bike is 2 and a half out, i put k n ns on it, turned them out anuther turn, runs fine, i was told not to touch the carbs screws, as itll make the bike run bad, she is any way?????
  11. RickCoMatic
    Technically ... The Mixture Screw Controls ... AIR.
    BUT, the AIR Passage is drilled so that it intersects with the Pilot FUEL Supply.
    As more AIR is allowed to "VENT" to the Vacuum of the Intake Stroke ... the AIR draws-up with it ... FUEL from where the Pilot FUEL Jet is drilled into the AIR Passage.
    This is why the Pilot Mixture Screw has such a SHORT Window of Mixture Regulating.
    Depending on the Volume of FUEL Jetted into the Passage the Mixture can be regulated until the Metering of the Fuel by the Jet regulates flow.
  12. yamahamaxim85
    england
    ta mate,ill try the air screws in, first,then if no good out, as it needs to get sorted,
  13. backblast
    backblast New Member
    Louisiana
    Speaking of ColorTune plug... Where can I get me one? was going to make me a Yics tool, but think I can get by without unless you guys think otherwise.
  14. bigfitz52
    Do a forum search on YICS and read the whole debate.
    There are very valid opinions both ways, the simple fact is that using the tool is what Yamaha recommends and it DOES make the process easier.
    You can accomplish the same state of tune without it, but it requires more luck and apparent skill than I personally have so I use it. I've tried sync'ing (and colortuning) both with and without, and came to the above conclusion by virtue of the experience(s.) Others have had different experience.
    You can order a ColorTune directly from the manufacturer, Morgan in England, but I believe chacal (see forums, supporting vendor, XJ4Ever) carries them also.
  15. zoutlaw
    zoutlaw New Member
    TO me it does not makes sense to NOT have the tool in when doing the air/fuel mix screws. The manuals say to stay away from them. But I understand the emissions they were trying to achieve by having the bike lean was beyond Yamaha's control due to regulations at the build date of the bike. Thanks for the answer. (Scratching my head now and trying to help catch worms)
    Joe
  16. bigfitz52
    OK, worms it is. The mixture screws were originally set using an EGA, which was problematic even for Yamaha dealers. We have the visual equivalent, the ColorTune, to assist in setting the mixtures rich enough to make the burn "happy." We probably do end up richer than the factory, but the motor is more reliable as a result.
    Trying to achieve ANY precise adjustment without isolating the cylinders is an exercise in frustration; that's what the YICS tool is for. Like I said, do a search on YICS and read the furor.
    I like my 550 that idles like a sewing machine. OK, both of 'em. (worms ahoy...)
  17. Carvall
    Carvall Member
    Seattle
    I had achieved better results cheking the plugs for color than the colortune!
  18. bigfitz52
    Agreed. FINAL mixture adjustment comes from real-world application.
    ColorTune gets you in the ballpark. I didn't believe in it until I bought one and used it. You do still need to do the final tweaks based on the plugs.
  19. RickCoMatic
    I set the Sync and Idle with the YICS Tool in place.
    Then, I pull the Tool and treat the Mixture to each Carb individually.
    My working theory on the process:
    "Tune it the way you are going to ride it!"
  20. Bushy
    Bushy Active Member
    FWIW I agree with Fitz and Rick, and the final tweak is very small.
  21. zoutlaw
    zoutlaw New Member
    Thanks all for the input. Question answered :D
    Joe
