Motorcycle enthusiast/ currently working on a project!
Discussion in 'Hangout Lounge' started by Urra, Jan 26, 2015.
  1. Urra
    Urra Member
    Miami, FL
    Hey! Name's Michael from Miami, FL!
    Working on my 1982 XJ 550 Maxim I bought about 3 months back that doesn't run and finally got the chance to add some pics of the project. I'm going to start using this thread as a progress keeper from now on! Future plans: Cafe Racer.
    Any advice would be greatly appreciated!
    Upgraded some parts because they were out of shape.//considering creating a simple,custom wire harness
    Upgraded parts thus far:
    -K&N air filters
    -New spark plugs
    -Gravity fed modern petcock
    -Clubman Handle bars
    -New Starter Solenoid
    *stripped most of her down to better analyze everything on the bike; I like to know what I'm working on.*
    Known issues:
    -Starter button doesn't operate.~I've switched the controls, switched the solenoid, cleaned the connections, checked the wires closest to the plug, still no reaction. Thinking it's the relay.
    -can't figure out where to lead that air hose coming from the crankcase
    -need to rebuild master cylinder
  2. Urra
    Urra Member
    Miami, FL
  3. Urra
    Urra Member
    Miami, FL
  4. Urra
    Urra Member
    Miami, FL
  5. Urra
    Urra Member
    Miami, FL
  6. Urra
    Urra Member
    Miami, FL
    IMG_0731.JPG That clutch assembly has me iffy >.<
  7. Urra
    Urra Member
    Miami, FL
    IMG_0732.JPG Neeeeeed to clean out that crank case
  8. Urra
    Urra Member
    Miami, FL
  9. Urra
    Urra Member
    Miami, FL
    IMG_0729.JPG These carb boots have me worried
  10. Urra
    Urra Member
    Miami, FL
    Update *
    Ordered new starter brushes because the starter wouldn't turn over anymore.
  11. Urra
    Urra Member
    Miami, FL
    When I got it, this plug was never connected, though I have the correct solenoid connection.
  12. zombiehouse
    zombiehouse Member
    Pomona, Ca
    The clutch arm return spring appears to be missing. Check the safety circuit. That could be why you are getting nothing from the start button if you have a fully charged battery. Before you do any more modifications, get her running. Those carb boots look bad. How do they look from the inside? If the inside is cracked too, replace them. You will probably need to replace them soon anyways. That plug in the last picture goes to the sidestand switch if one the wires is blue/yellow stripe and the other all black. This could also cause your starting problem.
  13. FtUp
    FtUp Well-Known Member
    pacific northwest
    you also need a throttle shaft seal, plastic washer and an "e" clip. those air filters will cause you all kinds of jetting woes too. you really should verify that you have good compression on all 4 cylinders before you spend any more money on that bike.
    FU
  14. Urra
    Urra Member
    Miami, FL
    The previous owner decided to chop off the wire from the oil filter/ side stand safety so I figure this could've also contributed to my dilemma? And I'm going to try the compression test as soon as I have the rebuild kit for the starter because it started failing.
  15. Urra
    Urra Member
    Miami, FL
  16. Urra
    Urra Member
    Miami, FL
    Ahhh that makes sense I'll check it out as soon as I get home! Also, regarding the choke, where should I keep it set when attempting to start the bike after I rebuild the starter? And is it possible to show me exactly how the clutch return spring would look when added so I have a better idea as to how it goes?
  17. Bigshankhank
    Bigshankhank Active Member
    Bastrop, TX
    When you say your starter " started failing" does that mean that it is trying to spin?
  18. Urra
    Urra Member
    Miami, FL
    Yes. I listened to the starter as much as I could and it mumbles but doesn't make a full rotation
  19. Urra
    Urra Member
    Miami, FL
    I could almost GUARANTEE that the starter has been bad from the beginning, never paid much attention to it and it almost bit my arm off.
  20. Stumplifter
    Stumplifter Well-Known Member
    near Irma, WI
    The more pictures you post, the more opportunities I can see for you to become the best XJ mechanic ever!
    Hope you didn't pay a lot for the bike; looks like the PO did quite a number on it.
    Don't loose your enthusiasm . . . .
    I recommend you start with pulling the carb rack and going to Church on it.
    http://xjbikes.com/forums/index.php?threads/in-the-church-of-clean.14692/
    Starter brush replacement (how did the o-ring seal in the picture above get so discombobulated?)
    http://www.xj4ever.com/starter brush replacement.pdf
    Brakes, brake lines, master cylinder, new tires, Petcock, control cables, fork seals, and rear shocks are probably all in your future. Plan on investing at least $800 in parts.
    Parts?
    Go to XJ4Ever (upper right hand corner of web page)
    Urra likes this.
  21. Urra
    Urra Member
    Miami, FL
    I didn't pay much! It looked like it was in good shape but hey I guess we learn out of mistakes huh. Seeing as this bike is pretty reliable and is loved pretty dearly by many people on this site I figure it should be a worthwhile fix. /
    The o ring... Ahh the o ring... I have absolutely no idea how an o ring could become that rattled up especially since it's in an enclosed area. I'll get started on the starter as soon as possible. Also, regarding the carbs. I have new pod(whatever you'd like to call them) installed but with the stock jets in the carbs. Any idea as to which size jets I need to purchase before cleaning out the carbs(waiting on my budget to be able to afford new boots)?
  22. Urra
    Urra Member
    Miami, FL
    image.jpg I found these gremlins (including two more under these three) soldered together(PO). Going to check out the wiring diagram as soon as I get home / unless someone knows by heart where these wires go. Looks like a mess
  23. chacal
    Looks like what comes off the main key switch......Big Red comes from the fusebox MAIN fuse, brown goes back to the fusebox and then splits into three separate wires, each one powering the other circuits (Lights, Ignition, Signals) in the fusebox, and the blue powers the rear tail light/brake light circuit.
    This connector/wires should be somewhere up near the front of the bike, hard to tell the position from the angle of the picture.....
    P.S. the orange and red/white stripe wire is the power feed to the left side (plugs # 1 and #4) ignition coil.
    Urra likes this.
  24. Urra
    Urra Member
    Miami, FL
    Taping the wiring temporarily ASAP
  25. Urra
    Urra Member
    Miami, FL
    can you snap me a pic of what it looks like? I can't find it:(
  26. Jherbst
    Jherbst New Member
    Nj
    if I'm
    they look to be power from ignition switch aand the other 2 are two your coils
  27. Rooster53
    Urra likes this.
  28. rocs82650
    rocs82650 Well-Known Member
    Middle Tennessee
    Huh? This one suprise me. Now, now, Stump...we want to encourage our fellow members but you were on the old site. Just about anything within function that can be done to a xj has been done. From rear wheel to front, soft tail to hard, dual to mono shocked, complete front end swap, mill swap, frame refab, trikes, fuel injected; you name it and its probably been done. Not to mention all the meticulous stock xj's. He has a nice build going but the best ever is a stretch. I honestly don't think there is a best. There's too many that are just that good; both stock and moded. I miss the gallery.
    Gary H.
    Urra likes this.
  29. Urra
    Urra Member
    Miami, FL
    I have seen most of them and have gained inspiration to go harder on this project. I really appreciate the push rocs! Waiting on the starter motor rebuild kit to come in still :/
  30. Urra
    Urra Member
    Miami, FL
    Yeah I see the little impression it's supposed to go in. I'll look for the piece soon
  31. Urra
    Urra Member
    Miami, FL
    Do you think this could be the issue? Maybe splice a fresh piece in between?
  32. Urra
    Urra Member
    Miami, FL
    image.jpg WOOO it came in, I'll get it installed soon enough(studying for tests)
  33. Urra
    Urra Member
    Miami, FL
    image.jpg Crooked screw is harder than I though
  34. Urra
    Urra Member
    Miami, FL
  35. chacal
    Yikes! That is the soft, dirty underbelly of a starter motor, no doubt..........
  36. FtUp
    pacific northwest
  37. Polock
    Oh my !
  38. Urra
    Urra Member
    Miami, FL
    Glad I'm not the only one surprised haha. Well, I'll post some pics of the progress right now. For some reason now it's really hard to spin after the rebuild, any ideas why?
  39. Urra
    Urra Member
    Miami, FL
  40. Urra
    Urra Member
    Miami, FL
    I believe the main problem is the rebuild kit's replacement baring... It didn't spin as smoothly as the original (Really hard to spin)
  41. Beekman
    Beekman XJ Grasshopper
    Erin, Ontario
    I believe spinning the starter by hand at the shaft end should feel tough to turn. I remember reading it somewhere on here. I think its because the mechanical advantage is fighting against you in that case (don't quote me on it)
  42. Urra
    Urra Member
    Miami, FL
    It's barely even turning now though, I have to really force it. I did remove this rattled up tape from the inside of the starter where I THINK the actuator's arm was making contact with in order to stop it from touching the metal shell
  43. Beekman
    Erin, Ontario
    Have you tried hooking it up to power to see if it spins?
  44. Urra
    Urra Member
    Miami, FL
    Yeah. It just sparks as if there was a short but I made sure no metal pieces inside were touching the frame.
  45. Rooster53
    From the starter How to Guide, this part is sometimes overlooked and is very important.
    ":::::::::::::::NOTE::::::::::
    When re-installing the battery cable to the starter, be absolutely sure that the "bolt holder" is not cracked, and be sure to use the o-ring and felt washers upon assembly. If this bolt is not well insulated it will cause a ground fault and the starter will not spin, nor will you be able to bump start the bike."
    This is referring to the stud that connects to one of the brushes and exits the starter. The large cable from the solenoid (POS) is eventually secured to the stud. The stud must have all the components installed correctly to insulate it from the starter chassis.
    Urra likes this.
  46. hogfiddles
    Just wait til you get into the carbs!!! Take a look at my "before/after" thread to get a sneak-peak at what you might be in for...........
    There WILL be substantial drag when trying to turn the starter by hand. That's the way they are. But if all you're geting is sparks, then yeah--something's still not right.
    Where did you get your parts from?
    Len-I bet the problem isn't the replacement part
    Some other company - I bet the parts are wrong
    dave
  47. Beekman
    Erin, Ontario
    He could've done what rooster has said, and cracked the insulator boot for the terminal post. I know I did it my first time haha gotta be careful tightening it
  48. Urra
    Urra Member
    Miami, FL
  49. Urra
    Urra Member
    Miami, FL
    I don't seem to have any cracks, I do recall removing this worn out tape (Maybe insulator) From inside when I was cleaning it out
  50. hogfiddles
    Then I will stand with what I said about the parts until proven otherwise.
    Dave
    Urra likes this.
