Mounting the airbox to an XJ 750
Discussion in 'XJ Technical Chat' started by ryanismyname, Nov 11, 2009.
  1. ryanismyname
    ryanismyname Member
    Baltimore, MD
  2. jarreddaughtry
    jarreddaughtry Member
    Smithfield, N.C.
    By the time I saw this auction it had ended. What kind of xj are we talking about? If it is a maxim I might can help, if it is a seca someone else will have to jump in.
  3. Lou627
    Lou627 Member
    Queens, NY
    Good buy! I sold my boots alone for 30 bucks. If he doesn't include hardware, you will just need to pickup a couple of bolts from the hardware store to attach it to the frame. Fix that crack with some epoxy, and hope he includes the top cover :)
  4. Bushy
    Bushy Active Member
    Hope you got the top cover coz its what holds the filter in place, having to remove engine to put the box in may be a nuisance, but in the end worth it.
  5. ryanismyname
    ryanismyname Member
    Baltimore, MD
    woah woah. You have to take the engine out to put the airbox in? Well F that in the A. Looks like I'm sticking with the pods!
  6. tcoop
    tcoop Active Member
    South Weber, Utah
    it can be put in with out removing the engine but it is a tight fit. The was a vidio posted here on how to do it
  7. Bushy
    Bushy Active Member
    Well you have to remove/displace engine to get the box out in one piece so ya must have to do that in reverse to get it in, in one piece. For ease of tuning its better in.
  8. TIMEtoRIDE
    That video applies to the 650 Maxim. . . Secas are a "no-go"
    Here's the easy way to remove and install XJ engines. . .
    http://www.xjbikes.com/Forums/viewtopic ... oader.html
  9. ryanismyname
    ryanismyname Member
    Baltimore, MD
    Hmmmm, what else has to be removed to slide the engine up? I might just strategically break the airbox, install it, then somehow epoxy it back together. It's just a plastic box.
  10. chacal
    Drop the front of the engine via removing both the upper and lower front engine mounting bolts.......and loosen the rear engine mtg. bolt, that way the engine can "tilt" forward and down a bit.
  11. bigfitz52
    after first removing the exhaust system.
    Yes, it's just a plastic box, but that "plastic" is some of the most adhesive-resistent stuff on the planet.
    You might be able to distort it enough to force it in if you warm it up first (soak in a tub of hot water) but I don't know.
    I DO know that it's not possible on the 550s.
