must pull main fuse to cut power
Discussion in 'XJ Technical Chat' started by apsolus, Dec 4, 2010.
  1. apsolus
    apsolus Member
    dahlonega ga
    heres one for the guru's. i just installed a fuse box cause po removed it for unknown reasons. after installing it, the ignition switch has become ineffective. as in wether its on or off i can start the bike and evertying like lights and signals work. only way to get the bike to turn off is kill switch or main fuse. my bike is an mk model according to clymer's wiring diagram. wish i had my dmm at the house but its at work. bike will start in any key switch postition. everything works but wont shut off, anyone have a clue?
  2. Metal_Bob
    Metal_Bob Active Member
    Bourbonnais, IL
    Assuming it didn't do this before installing the fuse panel...
    Go back thru all your connections and make sure all the colors EXACTLY MATCH. There are a few similar colored wires with tracer (colored) strips on them. Its only 4 fused on MY ride, so it shouldn't take that long to check.
    Beyond that wait for others to reply.
    Red, Red White, Red Yellow, Tan is what my ride has.
  3. apsolus
    apsolus Member
    dahlonega ga
    clean set up metel bob.
    im runnin four as well, i have double and triple checked my colors. your right they can be tricky to tell apart if your not being careful like the red yellow and red white wires. ill look again thanks. no it didnt do this before which has me thinking its someting i did. all the wires were just connected to one another without fuses. mabye the po knew about this and thats the only way he could get everyting to work. hmmm
    actually looking at your fuse panel i think i figured it out, my panel has individual inlets for the fuses to recive there power into each individual fuse but only one common ground for the other ground wires. wish i could show you what i mean but i got no camera
    quick question for you, i noticed you have a rubber fitting at the intake opening, does that serve an important purpose? cause i dont have one
  4. bigfitz52
    This is most likely your problem; there should be no "common" between any of them. You're feeding battery "hot" to the whole system all the time is what's apparently happening.
  5. Metal_Bob
    Bourbonnais, IL
    I have no idea if they rubber inlet boot is needed for smooth running.
    Check my DIY electrical post for my in process pics of my fuse panel install. Time and weather permitting, it was not that hard to make it clean looking.
    If I did it again (hope I never have to), I would have had all vinyl tube and none of the spiral wrap I used. (But I hadn't found the tubing at the stores yet).
  6. apsolus
    apsolus Member
    dahlonega ga
    did some checking looks like i crossed a coulple of wires (powers for neg wires) after making the corrections i now need to remove each individual fuse to get each circuit to shut down. now i can remove the main fuse and start the bike! ok my next mission is to find the proper fuse panel. ill keep you all posted :|
  7. Metal_Bob
    Bourbonnais, IL
    Nothing wrong with inline fuses (just not as clean of an install).
    If you can't find any locally, order from Chacal on here (just pm him your needs).
  8. apsolus
    apsolus Member
    dahlonega ga
    went into town which unfortunatly takes around 30 mins cause i live in the mountains, couldnt find the proper fuse panel. so i bough individual inline fuses (metal must be a phychic too) and the problem is gone. thanks for you help everybody. now its on to the rest of my problems. :D
