my 4th bike in 3 years of ridding
Discussion in 'Hangout Lounge' started by aushiasami, Mar 27, 2011.
  1. aushiasami
    aushiasami New Member
    mableton, GA
    94 yamaha xj600 with new carbs and engine. Traded my 90 nissan 240 for it. sadly it doesnt start. The previous owner said it starts but when he decided to put boots on to connect the carb to the air box it stopped running. It starts up and idle for a bit and then dies or if i hit the throttle it dies.
  2. cutlass79500
    lawrenceville georgia
    try putting the petcock on prime and trying it.
  3. aushiasami
    mableton, GA
    even with petcock on prime still no luck. i cant seem to put pictures on here
  4. BillB
    BillB Active Member
    Tulsa Oklahoma
    Idles till you apply throttle. Idle circuits seem to be working good.
    Sounds like a carb sync issue?
  5. cutlass79500
    is it blowing black smoke ? Dont know if you trust what the former owner says or not but if it ran before he put the air box on hows the filter? Thats about the only thing it can be. Your getting fuel out of the petcock correct ? Are the plugs wet? If the plugs are not wet and your getting fuel out of the petcock i would say more then likely floats are off. If it was the idle circuit plugged if you could coax it up to 2k or so should start running on the mains
  6. aushiasami
    mableton, GA
    how would i fix the sync
  7. BillB
    BillB Active Member
    Tulsa Oklahoma
  8. cutlass79500
    get your carb problems figured out before you try to sync them. The bike has to run right or you will be wasting your time. There are articles in here on how to do it and even how to make your own gauges good luck
