My "new" 80' 650 has horrible top end noise
Discussion in 'XJ Technical Chat' started by nejeff, Apr 16, 2012.
  1. nejeff
    nejeff New Member
    Just bought bike and no.2 is ice cold and motor makes worst noise I ever heard! No. 4 starts working after about 2 minutes (yes, this thing actually starts and idles!). Not sure what I am going to find tomorrow. Carbs rebuild is a gimme but something must be wrong in that top end. Any thoughts?
  2. nejeff
    nejeff New Member
    Oh, and I can feel kind of a vibration on the no. 2 exhaust pipe I don't feel on the others.
  3. hogfiddles
    could be you have a valve issue and have to do your clearance checks. You're probably going to want to pull the valve cover off and check the condition of the cams themselves, too. Make sure the guides look good, the gears look good, the chain is not slack, etc..... I did take one engine apart that was a strong running engine, and found a broken cam gear mount on an exhaust cam one time. Apparently it had happened before, and I could see where the bolts had scored the inside of the chain tunnel, but fortunately hadn't damaged anything else.
    We need more info, though...
    How many miles?
    previous shim checks?
    compression test?
    previous owner do any 'repairs'?
    previous owner actually KNOW how do the repairs?
    etc...
    If the previous owner is a member of this list, no offense intended.....:)
    Dave F
  4. nejeff
    nejeff New Member
    If it's as simple as valve adjustment that would make my day. PO bought it from another PO and both did not know a thing about motorcycles. I'm fairly sure the oil is at least 6 years old. I was actually shocked the thing started judging by the condition of everything when I went to look at it. It has about 18,000 on it and that's about all I know. The valve cover looks to have been removed and siliconed on in the past so maybe it had some attention under there? maybe? ...probably not. Valve cover is coming off tomorrow and compression will also be done. Hi haven't had a chance to get to far into this XJ thing but can I assume my motion pro valve tools for my XS will work on the XJ? Are these two motors of the same family? I will report back with my findings...Thanks!
  5. nejeff
    nejeff New Member
    Did compression test this morning. 1, 3, 4 are at about 120. No. 2 is at 90. Checked all clearances and they are a little tight but nothing crazy or far out of wack. Ideas guys?
