Mystery Master Cylinder
Discussion in 'XJ Technical Chat' started by luminaman, May 25, 2011.
  1. luminaman
    luminaman Member
    Clive, IA
    I have an 82 XJ 750. Unfortunately, I don't think the master cylinder on it is for this bike. The markings on the unit are 5/8 6 V I (or 1). Does anyone know how I can identify what master cylinder I actually have?
  2. marshallnoise
    marshallnoise Member
    Seca or Maxim?
  3. RickCoMatic
    Post a Photograph please.
  4. zap2504
    zap2504 Member
    Middletown, PA
    Secas have a cable-actuated MC mounted on the steering head; the Maxims have one mounted on the handlebar (conventional place).
  5. luminaman
    luminaman Member
    Clive, IA
    It's an 82 Maxim XJ 750. I cannot seem to attach a photo. I will gladly send to your personal email if you're willing.
  6. marshallnoise
    Try photobucket.com and host the image here. It will have the "[​IMG]
  7. luminaman
    luminaman Member
    Clive, IA
    Here's the link to the pic of my master cylinder. I ordered a rebuild kit, but the piston was too long. Ironically, it matched the one I removed. No wonder the front brakes never worked too well.[​IMG]
  8. luminaman
    luminaman Member
    Clive, IA
  9. luminaman
    luminaman Member
    Clive, IA
    Re: Mystery Master Cylinder 7A7
    On closer examination, I found the number 7A7 stamped into the cylinder. The number is located just to the left of the opening where the piston is inserted.
  10. schmuckaholic
    California
    That looks like the right one to me...
  11. RickCoMatic
    That the one.
    A pretty simple Test is;
    Mount the MC
    Fill 1/2 full.
    Pull Brake Lever and try to develop Hydraulic Pressure.
    Observe Fluid in Reservoir.
    IF, ... Brake Fluid squirts-up like Old Faithful, ... the Seals are Bad*
    * Worn, misplaced or Cylinder is Contaminated of Pitted.
    IF,, ... the Brake Lever can build-up pressure, ... the MC is pumping OK.
