need 5th gear ratio
Discussion in 'XJ Technical Chat' started by simusix, Feb 21, 2011.
  1. simusix
    simusix New Member
    hi, I,m building a trike and need the following info , does anybody know the 5th gear ratio for an x reg xj750,and middle gear ratio, ?.
    thanks simon
  2. bigfitz52
    From the Haynes, and I don't know if I'd 100% trust it, model-wise, so I'll give you the whole thing:
    "Top" (5th) gear 0.812:1 (26/32)
    Output spur gear ratio:
    XJ750J: 1.297:1 (48/37)
    All other models: 1.361:1 (49/36)
    Middle gear ratio: 1.055:1 (19/18)
    Final drive gear ratio: 2.909:1 (32/11)
    All I have for the 750s is the Haynes; I'm suspicious of everything being exactly the same, 650-750, except for the 750J's output spur. But this is all that's listed.
    Somebody with a factory book needs to double-check this.
  3. simusix
    simusix New Member
    thanks bigfitz52
    will try turn engine over and count turns in each gear through rear wheel. cheers
