need help identifying a 650 seca
Discussion in 'XJ Technical Chat' started by baby_bacon, Nov 23, 2006.
  1. baby_bacon
    baby_bacon New Member
    If anyone can help me get some info on this bike it would be greatly appreciated
    here are some pics
    I paid a total for 90 bucks for it
    and it runs and rides just need some tlc
    new fluids cleaning
    air filter
    just need some info on it
  2. AdeXJ
    AdeXJ Member
    Kent, UK
    U got a frame number - usually helps in identification
    90 bucks, a good deal in any currency!!
    Congrats on being member 1000
  3. BlueMaxim
    BlueMaxim Active Member
    Central Mississippi
    That's a 750 Seca.
    Need the first part o the VIN to know which year.
  4. baby_bacon
    The first 5 didgets are
    jya56
    everything else has coroded away
    i cant locate the vin number on the engine can someone help with that location with a picture or a detailed description?
  5. Hired_Goon
    Hired_Goon Member
    Oz
    Engine number should be on the top right hand side of the engine case.
    Just under the right hand side carb.
  6. bosozoku
    bosozoku Member
    Albany, Oregon
    It's a 750 Seca exhibiting evidence of carb-drool.
    There is a small flat on the front of the cam-chain tunnel that has the engines' displacement on it, in raised cast letters about 1/4" high. Look just below the head-gasket surface and you'll see it.
    This method of engine displacement label is pretty common...you just need to know where to look for it.
  7. baby_bacon
    How many didgets is it cause the only number i can find is like 9 didgets long
    and it is on top of the transmission
  8. Hired_Goon
    Hired_Goon Member
    Oz
    Yep, that is the engine number. It should match the last 9 digits of your VIN number if it is the original engine.
  9. baby_bacon
    awesome thanks
    so now i have the first 5 and the last 9 now i just need 3 more in the middle
  10. RickCoMatic
    Go get some ZEP Cleaner. Soak that baby, good -- full strength -- ... all over. Really lay it on thick around the stained areas.
    15 Minutes later ...
    Hose it off and see what needs some additional cleaner and elbow grease.
    Nice grab. Running is half the battle. Cleaning and Pimping is all just a matter of time.
  11. baby_bacon
    Yeah i was using some simple green and that was working fairly well but i will have to try that zep
    and someone filled it up with about 3.5 quarts of oil and it was backfiring into the intake but its all good and clean now
  12. BlueMaxim
    Central Mississippi
    Check again, That should be JYA5G, Really need the next digit but so far looks like an '82 Seca.
  13. kevineleven
    kevineleven Member
    Columbus, Ohio
    Looks like it's a Yamaha!
    You're welcome.
  14. RickCoMatic
    The WHOLE number should be heavily STAMPED on to the frame at the steering head. The numbers stamped into the frame are often covered with a Nomenclature Decal. The decal ages, fades and falls-off.
    The FRAME STAMP cannot. Lurking on the steering head right-hand side is the FULL - VIN Number. It should be 17 Characters. JYA35H004DA001273
    It might be painted-over. But, if you need the whole number to get the bike reg'd or Titled ... you'll find it there.
  15. Nick
    Nick Member
    Vernon, BC Canada
    Mine must be broken :lol:
    My bike only has 9 digits in total.
    The engine #, frame stamped #, and the frame decal # are all the same, but only 9 digits.
  16. kevineleven
    kevineleven Member
    Columbus, Ohio
    Mine has 9 stamped, 17 on the decal.
  17. baby_bacon
    Well, as an update
    the bike is working perfectly except for a small exhaust leak in the 1st cylinder and by small i mean fairly large but other than that it is perfect anyone know a good site for leathers?
