need help on valve cover gasket change
Discussion in 'XJ Technical Chat' started by jake williams, Mar 7, 2015.
  1. jake williams
    jake williams New Member
    collinsville il
    I have a 1985 maxim 700 the valve cover gasket is leaking i bought a new gasket but im not sure about a few things and i dont want to mess anything up if someone has some advice id appreciate it
  2. lostboy
    lostboy Well-Known Member
    Tillsonburg, Ontario, Canada
    Is it a paper gasket or rubber. If it's a rubber gasket you need to replace the rubber doughnuts on the bolts. It's the pressure of the doughnuts that seal the gasket.
  3. jake williams
    collinsville il
    Its rubber
  4. lostboy
    Check out the first page of air head valve adjustment in the how to section done by Bigfits.
  5. jake williams
    collinsville il
    Will do thanks
  6. Hotcakesman
    Hotcakesman Active Member
    South Dakota
    use lots of RVT and take your time
    also make sure you have new grommet seals
    otherwise you are wasting your time
  7. hogfiddles
    DON'T use a lot of rtv......clean the cover and clean the top of the head very well, go over the mating surface with brake cleaner or other fast drying de-greaser. Let it dry to bone dry.
    -using a VERY fine file and/or VERY fine wet/dry sandpaper, check the lip edge of the half-moons. I've seen many that have a very sharp burr right at lip before it drops in to the half-moon. If there is a burr present, it will cut into the gasket and cause premature failure there. Use the above and just de-burr the 4 lips if needed.
    -Put a thin bead of elmers glue in the valve cover groove to hold the gasket in place.
    -if you feel RTV is necessary, run a very thin bead around the mating surface. Let it 'skin' and install as normal.
    -using new valve cover bolt donuts should eliminate the need for RTV, though............
    Dave Fox
  8. lostboy
    When you have the valve cover off you should check the record the valve shim clearance.
  9. jmilliken
    jmilliken Well-Known Member
    Dillsburg, PA
    Yea.... If your gasket is leaking... You are past due for clearances
  10. jake williams
    collinsville il
    Thanks for advice
