Need Jet help
Discussion in 'XJ Technical Chat' started by Great_Buffalo, Sep 15, 2010.
  1. Great_Buffalo
    Great_Buffalo Member
    43.719908/-98.030276
    Call me stupid!
    I tore my carbs apart months ago and hads all the pieces laid out where I knew where they went when I put the carbs back together. In the mean time my son and his friends have been in the shop fixing bikes and cars. The organization of my carb parts is in disarray. They are all separated but not place of assembly. I'm having trouble with the jet placement, which one goes where. The carb exploded diagram in the manual is of no help. This is off a 650 maxum. anyone give a guy some direction?
    Thanks all
    Its been such a busy summer I haven't had a chance to work on it. Now I'm trying to get the old girl out at least once before snow flies.
  2. stereomind
    stereomind Active Member
    Tulsa, OK
    Main fuel jet (110) goes into the tall center pillar (screws into the emulsion tube).
    Pilot fuel jet (40) goes into the shorter pillar, towards the front.
    The smaller air jet goes in the middle hole under the diaphragm.
    The larger air jet goes toward the front under the diaphragm.
  3. Great_Buffalo
    Thank you kind sir, you have saved the day.
  4. mwhite74
    mwhite74 Member
    Don't forget the brass washers under the fuel mains!
