Needle jet O-rings
Discussion in 'XJ Technical Chat' started by Reed whitehead, Jun 7, 2021.
  1. Reed whitehead
    Reed whitehead Member Premium Member
    I have a question on where the O-rings go when you put the needle Jets back in if the threads on the needle jet are on top and the pointy part is the bottom does the O-ring go at the bottom or the top of the needle jet does it go o'ring washer spring from the bottom up or does It Go O ring washer spring from the top down the carbs are on a 82 Seca 750
  2. Polock
    o-ring is the last thing to put on
  3. Jetfixer
    Take needle ,install washer , install O ring all onto end of needle turn the carb upside down and install ( this keeps anything from slipping off as you install)
  4. bensalf
    bensalf Well-Known Member
    yorkshire ,england
    no one mentioned the spring!,
    with the pointy end at the bottom, slide the spring on ,then the washer, then the "o" ring
    k-moe and Jetfixer like this.
  5. mlew
    mlew Well-Known Member
    Apex, NC
    Then a dab of silicone grease smeared on the assembly to keep it all together while you drop it in the carb.
  6. hogfiddles
    MIXTURE SCREW, spring, washer, o-ring.
    there are no washers, o-rings on the needle jet. There is a BIG spring, but that goes inside the slide after the slide/needle ass’y is installed into the carb.
  7. Polock
    actually the needle jet is the brass thing the needle jet needle goes into
  8. Reed whitehead
    Thank you for the advice
  9. hogfiddles
    Also known as “the emulsion tube”
