Neutral gear
Discussion in 'XJ Technical Chat' started by DaveXJ, Jun 24, 2008.
  1. DaveXJ
    DaveXJ Member
    Southern MN
    Hey guys, My 83 maxim 750 is getting harder to find neutral gear when engine is running. When not running i can get it into neutral easy. It takes me sometimes several tries. Sometimes it goes on the first try. Is this normal for these or am i looking at some repairs?
  2. KAOS
    KAOS Member
    Newport, Maine
    My does pretty much the samething. I was going 2 post about it! But u did 4 me... :)
  3. Polock
    do a search for clutch adjustment, but sometimes it is kind of tricky
    i seem to find it easier to get neutral from second rather than first
  4. Stamplicker
    Stamplicker Member
    London Ontario
    See if your cables' rubbing on your windscreen. I have to give mine a tap once in a while to free it up and then N is np =)
  5. DaveXJ
    DaveXJ Member
    Southern MN
    Just needed to adjust the knob by the lever and all is fine now. I had too much play in the cable.
  6. invader_gir05
    invader_gir05 Member
    I have this problem in almost anything, i believe i lack the finesse
    but i have found it alot easier going from second down to N instead of up from 1st
