new battery, AGM or Flooded
Discussion in 'XJ Technical Chat' started by slackard, Aug 27, 2013.
  1. slackard
    slackard Active Member
    Earth, Terran System
    looking at a new battery since i cant stand flooded batteries -- theyre messy and high maintenance..
    for general 12v power storage i have a bunch of AGM batteries which work great for general use around the house (UPS, telescope, breadboard)
    What is the word on AGM (sealed) batteries for motor bikes? do they have the cranking amps necessary for an XJ? anyone suggest a particular brand or supplier?
    Does most everyone just stick to flooded batteries and their annoying maintenance requirements?
  2. FJ111200
    FJ111200 Active Member
    Crewe, Cheshire, England
    I've got AGM batteries on my 2 XS1100's and my XJR1200. Best batteries ever.
    I use these http://motobatt.com/
  3. sektorgaz
    sektorgaz Member
    Western MA, United States
    You could also try a Shorai LFX Lithium battery. Weight savings, minimal discharging, etc. Haven't tried it, but people seem to like them.
  4. Kilted_to_the_Max(im)
    Kilted_to_the_Max(im) Member
    Duluth, MN
    I'm a fan of AGM, being up north I like the strong cold cranking.
  5. jmilliken
    jmilliken Well-Known Member
    Dillsburg, PA
    AGM is the way to go!
  6. maverickbr77
    maverickbr77 Member
    Lowville, New York
    I went agm never going back to flooded.
  7. quebecois59
    I bought an AGM at least 5 years ago for my XS650 and I've also used it to crank my lawn tractor. It has never let me down once.
    AGM batteries are definitely the way to go.
  8. ElkHavenSeca
    ElkHavenSeca Active Member
    Sedro woolley wa
    Motto batt for my seca 750 . not a lick of trouble even after a long crank . great fit .... never going back to any other kind of battery !! ever
  9. slackard
    so, AGM then :)
    I like the Lithium idea.. didnt know there was a ready made product... I expected i would have to use LiFePo (lithium iron phosphate)cells.. ive seen people build car batteries using cells scavanged from dewalt tool batteries .. trouble isnt it getting a proper LiFePo 12v cell, its integrating a proper charging circuit so you dont cook the battery on the alternator.. could be a fun project for some of the more talented wire monkeys out there :)
    lithium battery tangent .. Last year i built a 50+mph electric bicycle on a 72v 20Ah LiMn (lithium manganese-oxide) battery. Its a fun commuter totally free of license or insurance restrictions. truly a go anywhur motorbike.
  10. Kilted_to_the_Max(im)
    Duluth, MN
  11. biggs500
    biggs500 Active Member
    Sherwood WI
    I have an AGM in my Maxim. don't know if you can leave them in the cold or not so i pulled it last winter. Put it in the bike in that spring without even a trickle charge and it fired right up.
    So I would say go with the AGM.
  12. biggs500
    Sherwood WI
  13. Polock
    here's your over charge protection
    all-battery.com
    or save some money and get a SLA gell battery, that's all i use
  14. darkfibre
    darkfibre Member
    Perth, Australia
    Motobatt
  15. mtnbikecrazy55
  16. RonWagner
    RonWagner Member
    AGM all the way. They also have more amps per given size (cubic inches) so if you can't find one the same size you can ususlly get by with a smaller one and still have more amps than the flodded one. Just shim the box so it doesn'r bounce around.
  17. cutlass79500
    lawrenceville georgia
    No mess No fuss AGM what i use
  18. slackard
    Ok, this thread is old, but covering the bases for anyone searching for an AGM battery for their 82xj650
    Ended up buying the AGM battery linked below, which is exactly the same size as the stock / flooded cell, and cheaper than any local/retail option:
    Scorpion YT12C, AGM 180CCA
    http://www.scorpionbattery.com/powerspo ... yt12c.html
