New Clutch Break-In Procedure/Time???
Discussion in 'XJ Technical Chat' started by i_am_the_koi, Jun 13, 2011.
  1. i_am_the_koi
    i_am_the_koi Member
    Napa, CA
    So I just did my clutches on my 93 xj600
    Piece of cake really. Not having to rotate the steels made it easy. My question is, "IS there a break in procedure or time span" I should be aware of. Granted I'm not going straight out and putting down my best time on the track, but I did want to break them in slowly if that makes sense to get the longest life I can.
    Koi
  2. bigfitz52
    Not really; I wouldn't beat on it super hard until you've got a couple hundred miles on it, but it's not really a concern.
    You did use new springs, right?
  3. i_am_the_koi
    i_am_the_koi Member
    Napa, CA
    Yup, new springs, new steels and I did a quick 3 point check with a feeler gauge to check for warping, even soaked my frictions, :p
  4. i_am_the_koi
    i_am_the_koi Member
    Napa, CA
    Dissassembly
    Looking inside
    Burnt Disk
    Dot on pressure plate
    Dot on Clutch Boss
    Hmmmm, this is different.... Took me 3 tries to get the clutch lever properly alligned so that the cable would install correctly.
  5. cutlass79500
    lawrenceville georgia
    you did it the right way just dont slip the heck out of it and drive like a normal human for a short while just so the friction plates wear completely flat against the steel plates last thing you want is it to get super hot and glaze everything
  6. marshallnoise
    marshallnoise Member
    Nice job! I would do as cutlass states; drive it sane for like 100 miles with some gradual hard pulls with the clutch fully engaged. Just don't drop the clutch at 5K. Clutches are engine brakes.
    I just lubed my clutch cable yesterday with a funnel, electrical tape and 10w-30. And at the same time, did another readjustment to the clutch. Amazing difference. Actually can pull the front wheel off the ground now.
  7. i_am_the_koi
    i_am_the_koi Member
    Napa, CA
    Thats wot I was pretty much going to do, do a easy cruise up and down the Napa valley, 75 miles no more then 50 mph due to traffic, general increases and decreases in speed and just trying to be smooth on the shift, probably no more then 6-7k on the rpm throughout for the first ride or two
  8. bigfitz52
    Which is why I recommend removing the little lever; turning the throwout shaft CCW until it stops, then reinstalling the lever rather than removing/reinstalling the cover hoping to get it "indexed."
  9. i_am_the_koi
    i_am_the_koi Member
    Napa, CA
    Hahaha, I am sorry, I failed to see your recommendations in the annotations. I figured it out and did it without screwing up my gasket!!!
