new clutch perch and lever ?
Discussion in 'XJ Modifications' started by brenton, Feb 21, 2006.
  1. brenton
    brenton Member
    australia
    hey guys i changed to flat style bars , and i was wondering if there was any other clutch lever that fit and are easier to operate ?,the lever sticks out to far for my liking. also my clutch is pretty stiff atm, will greaseing the cable make much of a difference ?
    thanks brenton
  2. woot
    woot Active Member
    You should lube the new cable - it will extends it's life and make it feel like a million bucks.
    You can use a different clutch lever and bar assembly - just make sure you get enough sweep to properly move the clutch... if you don't you might have to change the length of the lever arm on top of the clutch basket (shorter I would guess?) to compensate.
    at this point I'd be looking for yamaha controls I liked better - same tube size, same reverse thread on the right bar... it's just going to be easier and maybe cheaper.
    Woot
