new fuse block with common ground ... ok ?
Discussion in 'XJ Technical Chat' started by blame_the_po, Sep 10, 2009.
  1. blame_the_po
    blame_the_po Member
    Boston
    will this work ?
    TIA
  2. dwcopple
    dwcopple Active Member
    bay city, michigan
    yessir
  3. blame_the_po
    blame_the_po Member
    Boston
    figured I would double check here before messin w/ wires. Thanks .
  4. wizard
    What is it we are grounding here?
  5. MiCarl
    My question too. Nothing grounds at the fuse box.
    If you mean a common hot it's not ok. They are individually switched.
  6. blame_the_po
    blame_the_po Member
    Boston
    ah, they are individually switched. So something like THIS will not work. I need one like with individual terminals...
  7. chacal
    That style (the Bussman box) will work, but you'll need to add a relay in-between the battery and the box that is triggered by the ignition switch brown wire......the relay will then engage and "turn on" the fusebox.
    The hot lead going to ignition switch (big red wire) would need to be fuse-protected.
  8. RickCoMatic
    I wouldn't suggest doing any "Re-Engineering" to the Fuse Block.
    A Simple 4 or 6 Terminal Fuse Panel is all you really need.
    Don't get involved with Circuit Breakers or Blocks requiring "Grounding"
    Where possible ... abide by the "K.I.S.S. Rule"
    Keep it simple; stupid!
    A GOOD Fuse Panel replacement goes a long way toward keeping the Bike running without problems.
  9. Dusj1716
    Dusj1716 New Member
    Can someone suggest a good fuse panel replacement for an '82 XJ750? I lost all electrical, and have power from battery to main fuse but nothing on bike side of fuse panel.
  10. chacal
    Hey Dusj1716, send me a PM, I can get you a proper replacement fusebox!
  11. Robert
    ^^^Yes he can folks, and that ain't all either!!!
