New horn: no beep, just clicks
Discussion in 'XJ Technical Chat' started by c_muck, Aug 1, 2011.
  1. c_muck
    c_muck Member
    Minneapolis, MN
    My seca didn't have a horn at all when I bought it so I picked up a K&S 12v compact horn. I found the wires where the original horns were snipped off and I wired in the new horn, but when I turn on the ignition and push the handlebar button all I get is a little click. I also tried it with the engine running but still nothing. Any ideas on what my problem might be?
  2. skyhawk
    skyhawk Member
    Northern Virginia
    I'm no pro here, but you could disconnect and put on a meter, push the button and see if you read 12 volts. That's what my old horn did... just click with no sound.
  3. Metal_Bob
    Metal_Bob Active Member
    Bourbonnais, IL
    You may NEED a relay.
    The horn button can be used as the on/off source for the relay.
    My electrical post has some DIY info/pics.
  4. SQLGuy
    SQLGuy Well-Known Member
    Some horns have a screw on them that needs to be adjusted for them to honk correctly. Is there a flathead screw that doesn't seem to connect to anything?
  5. RickCoMatic
    Consider yourself lucky.
    Mine don't even click!
    When I press the Horn Button, ... every once in a great while ... they do emit some low-level hum that makes folks take-out their cell phones and say hello.
  6. zap2504
    zap2504 Member
    Middletown, PA
    Classic symptom of the horn needing adjustment (the tiny - usually Phillips-head - screw on the back). Horns are basically electrical relays that are constantly connecting/disconnecting. The sound is produced by a metal diaphragm connected to one end of the "relay" arms. If there is only a "click", then the "relay" is not automatically disconnecting. Adjust tiny screw for max sound (shouldn't need much adjusting).
  7. c_muck
    c_muck Member
    Minneapolis, MN
    I did try messing with the adjustment screw a little but to no avail, would it need to be screwed in further or backed out?
  8. mwhite74
    mwhite74 Member
    I'm wondering if the horn mount (bracket) isn't corroded or something. it's not a bar but a bunch of metal leafs right?
  9. Metal_Bob
    Bourbonnais, IL
    Along that train of thought... does the new horn have its own ground wire or grounded to frame? If to frame, did you repaint the frame? Is the frame/bolts all rusty?
  10. c_muck
    c_muck Member
    Minneapolis, MN
    There is no separate ground wire on the horn, I assume it must ground to the frame mount. It came with two strips of metal for mounts, but they are both fully painted. I might try roughing up the paint where it meets the frame to see if that does anything.
  11. MoralDK
    MoralDK Member
    Spokane
    Before I put my bike up...over 10 years ago...the horn didn't work at all. After recently putting the bike back into action, the horn works great, without even touching it. Wierd...
  12. Bomonghani
    Bomonghani Member
    Indiana
    May want to check to see if your metal strips are conductive after roughing up... Mine weren't so I was left to crate a lead line.
  13. RickCoMatic
    I thought I could get some noise back out of mine.
    I disassembled them.
    The interior mechanism, ... where the Contact Points and the Electromagnet set behind the Vibrating Diaphragm Disc ... was all rusted badly.
    Beyond hope.
