New problem (with my speedo)
Discussion in 'XJ Technical Chat' started by sushi_biker, Feb 7, 2009.
  1. sushi_biker
    sushi_biker Member
    I had put together a working speedo drive gear. I got a few miles out of it. When I took apart the failed unit, the cable had sheared off down at the bottom. After putting a good cable down into the tube (and drive gear) it sheared off again after a few dozen miles.
    Any idea why? I lubed and greased everything pretty well.
  2. MN-Maxims
    MN-Maxims St. Paul Minnesota
    Saint Paul, MN
    Cable housiing kinked or damaged?
  3. sushi_biker
    sushi_biker Member
    The tube? Doesn't look like it but I'll re-examine it.
  4. MN-Maxims
    Saint Paul, MN
    Yea flex the cable housing and see if there is a bad spot in it. The plastic on the outside might be ok but the inside could be bad. That could bind the cable and snap it.
