new to forum. just baught my xj today. help please
Discussion in 'XJ Modifications' started by xharleyx, May 28, 2009.
  1. xharleyx
    xharleyx Member
    Pikeville, KY
    baught this today for $500
    runs great
    I'm going to make this into a bobber. if i take the mufflers off and run straight pipes will it hurt anything? i know nothing about carbs or motors. i don't know how to "re-jet" or anything. can someone point me in the right direction. i tried searching but cant really find what I'm looking for.
    any help is appreciated and i look forward to your guys help in the future!
  2. wizard
    Welcome, great looking bike. IMHO too good to chop.
  3. cokeman
    cokeman New Member
    Lethbridge, Alberta
    DIBS on the mufflers!!!!!! Seariously, Are you going to sell them?
    Darrell
  4. jgb1503
    jgb1503 Member
    Near Utica, NY
    Definitely too good to chop. But if you do, second dibs on the mufflers ;-P
    Like the handlebars - are those stock? (does anyone know?)
  5. chacal
    Looks like stock bars to me....
  6. jarreddaughtry
    jarreddaughtry Member
    Smithfield, N.C.
    running strait pipes is bad on the piston rings(no back pressure). as good as condition as the bike is in i would advise to polish it up a bit and sell it to make a profit or ride as is.
  7. meister66
    meister66 New Member
    Don't sell the mufflers till you ride around for a couple of hours with them off...:)
  8. jarreddaughtry
    Smithfield, N.C.
    by the way those are stock handlebars the same ones are on my parts bike.
  9. organizedinsanity
    organizedinsanity Member
    Running the bike with straight pipes wont hurt the engine due to a lack of backpressure. That is a myth. On a 4 stroke engine you really dont want back pressure anyways, you want exhaust scavenging. As long as you keep the stock collector box you will retain most of the scavenging effect.
    The main problem is going to be running the engine lean. These bikes run pretty lean in stock form and by removing the mufflers you will make it much worse. Lean=heat and detonation and both of those are bad for our air cooled engines. The bike wont run the same after you modify the exhaust, you will lose quite a bit of bottom end power. You can rejet the carbs to try and richen the mixtures up a bit but it can be difficult even for carb pro's. There is much trial and error involved as well.
  10. jarreddaughtry
    Smithfield, N.C.
    believe what you want its not MY bike.
  11. organizedinsanity
    Backpressure would be needed if you stuck a 2 stroke engine on your bike. On 4 strokes it is an undesired effect. You arent going to hurt the engine unless you run it seriously lean or run it with no exhaust whatsoever. Running with no exhaust is an easy way to warp exhaust valves but the stock headers are lon enough you dont have to worry about any of that happening.
  12. coachholland
    coachholland Member
    Georgetown, KY
    Where are the bikes like this in Kentucky? I've not seen a Maxim under $1500 ever and am always looking on Craigslist.
    Agreed with some of the others. That bike is too nice to chop.
  13. Bushy
    Bushy Active Member
    Yeah me to, too good to chop!!!(don`t cut that lamb into small pieces of meat)
  14. xharleyx
    xharleyx Member
    Pikeville, KY
    this came from WV although i live in kentucky
    i think i'm going to put some old sportster mufflers i have lying around on. don't care about sound just looks really
  15. coachholland
    coachholland Member
    Georgetown, KY
    The sound AND looks will be better. Definitely worth that mod.
  16. dwcopple
    dwcopple Active Member
    bay city, michigan
    since you said you know nothing on carbs and jetting...LEAVE IT ALONE.
