Newb Carb Rebuild - Thread for questions - Help appreciated
Discussion in 'XJ Technical Chat' started by eman1974, Mar 10, 2012.
  1. eman1974
    eman1974 Member
    Halifax, NS, Canada
    I've started this thread in order for you fine experts to help me along my carb rebuild. This is my first carb rebuild, so bare with me.
    I ordered all the parts I "need." from chacal - mostly seals, screws and the rebuild kits.
    So my first issue is part identification so that I know which parts I actually have replacements for.
  2. tskaz
    tskaz Active Member
    Saint Louis, Michigan
    The rubber o-rings on the "T" are fuel rail o-rings, you need 6 per carb rack.
    The T and straight fittings made of brass all take these o-rings.
    These parts are what make up the fuel rail.
    The brass parts can be polished with a scotchbrite pad.
    As for the screw on the throttle arm, take it to your local bolt supply and you should be able to get a stainless screw for less than 50 cents.
  3. eman1974
    eman1974 Member
    Halifax, NS, Canada
    Well right now it looks like I may have the wrong make of carbs for my bike. Thought they were Hitachi - but looks like they're Mikuni....
  4. tskaz
    tskaz Active Member
    Re: Newb Carb Rebuild - Thread for questions - Help apprecia
    From what I can see in the pics:
    At least one carb hat is from a Hitachi. Mikuni carb hats were not slanted.
    Also, Mikuni carb bowls did not have a nipple on the drain port. Can't see which style bowls are on yours.
    Hitachi carb bowls
    Hitachi hats
    Side view with Hitachi symbol on carb body
  5. eman1974
    eman1974 Member
    Halifax, NS, Canada
    Hmm, ok, I see the Hitachi mark now.
    However, what is causing my confusion is carb #1. The one on my bike is different. See the attached pic.
  6. tskaz
    tskaz Active Member
    Hmmm. Have you measured both sets? They may not be the same size.
    I would measure the openings and send the measurements and those two pics to Len - info "at" xj4ever "dot" com and ask him. If anyone would know it would be him.
