Newer carbs on 81 650 maxim
Discussion in 'XJ Technical Chat' started by swirl, Feb 17, 2015.
  1. swirl
    swirl New Member
    Ellesmere Port, Cheshire, England
    As the heading says anyone know of any newer carbs which are pretty reasonable to fit to a 1981 xj650 maxim
  2. FtUp
    FtUp Well-Known Member
    pacific northwest
    the best you can hope for is as new as 1983.
    FU
  3. Gulrok
    Gulrok Member
    Washington
    Unless you're into fabrication, there are no newer carbs to fit on these ancient bikes.
  4. MattiThundrrr
    MattiThundrrr Not a guru
    America's friendly hat
  5. hogfiddles
    the carbs from all xj650 maxims and all xj 750 maxims from 1981 up to 1983 are the same except for the jetting. (there are some little differences in the 1980 xj650 carbs, but I think they are still useable on the later ones, IIRC. If you you're looking for a newer set, your best bet is to get a good set to start with, and then do a total rebuild. If you mean NEW stuff, then, as other said.....you're going into more expensive territory with fabrication, swapping systems ,etc.............. and it will probably get very expensive for you very quickly. Oh, did I forget to mention probably very frustrating, too?
    Good luck, keep us posted with what you develop.
  6. jmilliken
    jmilliken Well-Known Member
    Dillsburg, PA
    If you are gonna do all that... why not go microsquirt efi?
  7. swirl
    swirl New Member
    fabrication is no problem, I was just wondering if there was a near enough straight fit, i'll have a good read of the threads above cheers for the replys.
