ngk iridium in a bike?
Discussion in 'XJ Technical Chat' started by NS_Rider, Feb 17, 2012.
  1. NS_Rider
    NS_Rider Member
    I just put these in my car, and notice a difference in how my car idles, and accelerates. I was just wondering if anyone tried them in a bike, or should I stick with regular NGK
  2. SLKid
    SLKid Active Member
    Troy, Va (Charlottesville)
    I usually put em in my GFs Ninja500. But honestly I think its one of those situations where, "I just changed my oil" or "I just washed my car and now she runs better"
    Mind over matter situation.
  3. RickCoMatic
    Iridium Plugs are a "Long-lasting" Plug that works best in applications where there is a continuous "Lambda Circuit" monitoring the Air~Fuel Mixture and making Mixture adjustments continuously while the Engine is running.
    Air Flow Metering, Oxygen Sensors and High Frequency Opening and Closing Fuel Injectors present an almost ideal Mixture to the Combustion Chambers in an Infinite Loop.
    The highly controlled environment within the Combustion Chamber on Fuel Injected Engines allows the Iridium Plug to outlast conventional Plugs.
    In our Bikes, we have little control over the Mixture and can erantly leave the Enrichment Valve open too long fouling Plugs.
    Along with the foibles of Wasted Spark, aging Coils and Engine performances generally deteriorating each day, ... there's good reason to use Plugs that you are going to run a few thousand miles and replace.
    Iridium Plugs are a little pricy to put in a unsophisticated situation.
    But, Madison Avenue Ad-writers are paid Big Bucks to make everybody think that too use anything other than Iridium Plugs is a big mistake.
    They spend more on advertising than they do manufacturing the Plugs.
    http://www.youtube.com/watch?v=9NvPemHiFxY
  4. bigfitz52
    I was going to say that they're fine but basically a waste of money, for exactly the reasons Rick spelled out.
    Your XJ will "beat up on" premium plugs just like it will standard plugs; I replace mine every 2000~3000 miles because the electrode straps erode. You can buy a whole LOT of standard NGK's at $1.99ea. for what you pay for one set of Iridium plugs.
  5. devo1
    devo1 Member
    Kansas
    I'm gonna try em. I picked up a set at the auto parts store for 40.50 including tax. That's actually 10% of what I paid for the bike! :oops:
  6. RickCoMatic
    $40.00 for Spark Plugs.
    The true test is: Red Light -to- Red Light.
    Are those 40-Dollar Plugs going to get you down to the next light before the guy right next to you, running Champions?
    Or does having your Madison Avenue Mo-Jo woikin' ... make you faster?
  7. devo1
    devo1 Member
    Kansas
    I own 7 bikes, race motocross and go on bike adventure trips. It would totally blow your mind what I spend on bikes. But I'm glad you're concerned.
  8. sanoke
    sanoke Member
    Centennial, CO
    I do feel a noticable difference when I run the Iridium plugs. To me, it's worth the money.
  9. RickCoMatic
    The Iriduim Plug is advertised as a Performer.
    It's really primarily intended to OUTLAST conventional Plugs.
    We all spend a good deal of dough keepinp-up two-wheelers to play on.
    My duty is to try to save the Membership a buck of two when the situation arises.
    There's NO reason to run YAMALUBE, ... for instance.
    YAMAHA Oil is just Oil that gets filled into Bottles that say Yamaha on them.
    Yamaha isn't an Oil Company.
    They are an expensive Bottle Company.
    Likewise, Iridium Plugs are not a wise choice for our Bikes.
    Iridium Plugs were developed to save Technicians from having to do costly Plug changes on Transverse V6 and V8 Engines, and those Automotive Plants where changing Plugs requires labor-intensive removal of Intake Plenums, Manifolds, Decorative Shrouds; even undoing Motor Mounts and rotating the entire Engine Block to gain access to a Bank of Plugs.
    Our Bikes are engineered to make exchanging Sparks, ... real easy.
    So that they'll be changed at regular intervals.
    Inspected ... frequently, ... to monitor tuning adjustments; and quickly, ... in the event that one becomes fouled and fails to fire.
  10. sanoke
    sanoke Member
    Centennial, CO
    Objectively, what you say makes perfect sense. However, subjectively I notice a significant difference between standard and Iridium plugs. Several times I have switched back to regular plugs and each time I was disappointed with the smoothness of the engine. To me it's worth the extra money to get that silky smoothness in how the engine runs. I even change them out at the same interval as regular plugs to retain that smoothness.
    Likewise, I could get the same buzz from cheap vodka that I get from a fine scotch but I enjoy the flavor of the fine booze. Maybe it's all in my head but if spending a little extra money gives me the perception of somthing better that I enjoy, then it's worth it to me.
    Life isn't all black and white. Sometimes you have to let a little gray through.
    Happy Trails!
    sanoke
  11. TIMEtoRIDE
    I periodically file electrodes to square them up and gap to the tight side of spec, at 0.027 . I've read that it takes 27% less energy to jump the gap on fresh plugs, so a comparison of New Iridiums and old plugs just isn't fair.
    I also index the plugs for that mythical 1% more power.
  12. TECHLINETOM
    TECHLINETOM Member
    Deerfield OH
    I use platinum plugs which were developed by Bosch to remedy weak ignitions. They also last much longer ( I put 100,000 miles on a set on my 1969 Firebird). Iridium plugs last 3 times longer than platinum plugs. So exactly how long is 3 times forever?
    I use and recommend the autolite app3923 double platinium plugs.
    They don't have removable tips but they are resistor plugs si the resistor plug caps cannot be used.
    They are cheap too!
    The double platinum plugs are only better than the regular platinum when you are running coil packs they aren't any better when you have a distributor.
    The Bosch Platinum plus 2 and plus 4 plugs eliminate the need to index the plugs as they use a side gap.
    However noone has been able to tell me why more side electrodes is supposed to be better.
  13. RickCoMatic
    A Spark Plug arcs for a very short duration.
    The length of time that it takes for the Plug to Fire is measured in:
    Microseconds!
    Faster than an involuntary eye-blink.
    Of less duration than a fast photo-strobe.
    Requiring an Oscilloscope to calculate the duration of the event.
    This is a Microsecond:
    A microsecond is an SI unit of time equal to one millionth (10−6) of a second. Its symbol is µs.
    A microsecond is equal to 1000 nanoseconds or 1/1000 millisecond. Because the next SI unit is 1000 times larger, measurements of 10−5 and 10−4 seconds are typically expressed as tens or hundreds of microseconds.
    Makes me wonder why you spend any more time on Installing a New Spark Plug in an XJ-Bike Engine other than making sure the Plug is Tight and the Cap is on firmly.
  14. TIMEtoRIDE
    MSD had a booth at the Stock Car Trade Show in Daytona. They had a display with a three inch spark continuously running at 8,000 RPM, and with the MSD turned on, each spark event had up to 6 individual sparks. (all at 50,000 volts)
    The Rep was standing there, burning holes in his business card, demonstrating how much stronger MSD was over stock, then inviting passers-by to do the same.
    Yeah - - he got me !!
    His card had a paperclip taped to the bottom, preventing him from being shocked.
  15. TECHLINETOM
    TECHLINETOM Member
    Deerfield OH
    An MSD @ 8k is single spark. The multi-strike ends @ 3k. below 9:1 compression the super hot spark doesn't do much. Above 9:1 compression it can be a dramatic improvement.
  16. darkfibre
    darkfibre Member
    Perth, Australia
    You sure about that?
    I will have to put the scope back on my bike, but my memory tells me the spark was almost a half a millisecond.
  17. adrian1
    adrian1 Active Member
    And now 12 months later, what do folk think about the multi (4) electrode plugs?
  18. TIMEtoRIDE
  19. RickCoMatic
    The only good answer befitting this question is:
    "If you want to spend the dough for expensive Plugs that do THE EXACT SAME THING that the less-expensive Brand-X does, ... then, knock yourself out!"
    Bear in mind.
    Prescribed Maintenance says replace the Plugs every 75-Hundred miles.
  20. quebecois59
    I remember I noticed my Maxim-X was a lot easier to start when cold, and the engine idled and rev'd up a lot more smoothly after I've put new Dyna coils and Iridium plugs. I can't tell if the improvement would have been the same with new coils and regular plugs, though.
  21. adrian1
    Yeah OK I got the lowdown on Iridium....I'm asking about plugs with 4 electrodes...still not worth bothering or?.....Its only for a single cylinder machine
  22. MercuryMan
    MercuryMan Active Member
    Springdale, NWA
    I swapped E3 plugs for my new perfectly gapped NGK's in the 550 and there was an immediate and noticeable difference. Just as an experiment I idled the bike downward with both sets of plugs. The NGK's would let the bike idle right above 900rpm before it would stumble and usually die, but with the E3's it idled just fine below 800rpm. Of course I put it back to spec afterwards.
    It also starts a couple of revolutions quicker with the E3's. Does it have more power or top end? Haven't had any REAL way to measure that but it feels like it does. Mileage creeped up from average of 48-52 to 50-54. Another nice plus with the E3's is there is no gapping required! I'm sold on them but they didn't make my 550 into a 900. :)
  23. johnnyx
    johnnyx Member
    london ont
    I am picking up a set of iridiums tomorrow-will see if theres any difference when the weather warms up here in london.at ten bucks a peice i hope so.
  24. 750E-II_29Rbloke
    South Cheshire, UK
    As has been said, nothing really WRONG with spending the money if you got it, personally I'm going to be fitting stock plugs (minus the resistor spec) in mine & changing them regularly, seeing as modern plugs don't seem to like being cleaned up after any foul-up as older ones used to...
  25. RickCoMatic
    (Sound Effects)
    Sub-sonic Fighter Jet low-level fly-by.
    (Cue Announcer)
    YOU WANT YOUR BIKE TO FLY
    YOU WANT MORE POWER
    (Sound Effects)
    Massive Clap of Thunder.
    INCREASED TORQUE
    EXTRA HORSEPOWER
    (Sound Effects)
    High energy discharges of a huge Van de Graff generator.
    UNBELIEVABLE ACCELERATION
    DOUBLE THE MILEAGE OF A TANK OF GAS
    (Sound effects)
    Formula-1 Race Car accelerating through the gears.
    YOU'RE BIKE WILL GO SO FAST
    YOU'LL ACTUALLY GO BACK IN TIME!!
    (Sound Effects)
    Teenage girls screaming for The Beatles.
    YOU'll BE LOTS MORE POPULAR
    SIZZLING HOT BABES WILL WANT YOU
    YOU WANT TO BE PLUGGED IN
    SO WE GOT A PLUG FOR YOU.
    (Sound Effects)
    Rapid Heart Beat!
    ELEVATE YOUR PULSE RATE
    GET THE REVOLUTIONARY NEW
    PULSTAR PULSE SPARK PLUGS ...
    (Sound Effects)
    Isle of Mann T-T Rider flashing by.
    BUY PULSTAR PULSE PLUGS
    GET THEM ... TODAY!!!
    http://www.jpcycles.com/product/406-672 ... 4AodRCMA8w
  26. 750E-II_29Rbloke
    South Cheshire, UK
    So the plugs are each their very own CDI ignition system in a package shaped to look just like a... plug???
    Imma get me some a'those on order! :roll:
    EDIT-: and surely if they actually do as they say, they'd throw the timing off?
  27. adrian1
    You're a funny man Rick! Pls stick around!
