Ngk vs,Nippon,dinso..?For Seca 750 who's the best
Discussion in 'XJ Technical Chat' started by Tim morris, May 6, 2016.
  1. Tim morris
    Tim morris Active Member Premium Member
    Hopatcong NJ 07843
    Can't decide ?
  3. tabaka45
    tabaka45 Well-Known Member
    Brunswick, Georgia
    Agreed
    Tim morris likes this.
  4. cgutz
    cgutz Well-Known Member
    SE South Dakota
    I've only used NGK in my xj550. Why would I try anything else?
  5. joeperezis
    joeperezis Member
    Hudson, Illinois
    NGK user here also.
  6. Yardawg
    Yardawg Active Member
    Hatch NM
    Yep, NGK is what I use too
  7. Polock
    whatever's on sale
    Tim morris and Big swede like this.
  8. XJ550H
    when in doubt go with factory spec part
    NGK
    rocs82650 and Stumplifter like this.
  9. Big swede
    Big swede Active Member
    Gothenburg,Sweden
    Agree with Polock, you won't feel any difference.
  10. k-moe
    Sometimes you do. There are a few manufacturers who claim equivalency, but don't deliver. I can't recall exactly which specific brands, but there are a few threads where changing to an NGK solved rough running problems (even after having swapped for new plugs of the same brand that caused the trouble).
  11. Big swede
    Gothenburg,Sweden
    As long as you buy plugs with the right specs, it won't matter
  12. k-moe
    True, but (as I implied) not all manufacturers actually make their plugs to the stated spec (including NGK on occasion).
  13. TheCrazyGnat
    Central PA
    I can speak anecdotally that you should go with the ngk bp7es. I had something else, I forget the brand, but it was acting almost like the carbs needed to be cleaned. I switched what was on the bike when I got it (i forget what they were) and things smoothed right out.
  14. rocs82650
    rocs82650 Well-Known Member
    Middle Tennessee
    I use NGKBP7es.
    Gary H.
  15. Tim morris
    Hopatcong NJ 07843
    Tallyingthe vote ngk have it thanks
  16. Myron
    Myron Member
    Winnipeg, Manitoba, Canada
    I'm havingtrouble getting NGK BP7ES here. Supplier says no longer available in Canada. Had to go to Autolites for the equivalent. Will find out how well they work this week. Only non resistor plugs I can get.
  17. DrewUth
    DrewUth Active Member
    South Jersey
  18. Jetfixer
  19. k-moe
    That is dissapointing. Shipping and fees into Canada are horrible. If the Autolites dont' work out try Ebay. I found a few listings at just under $6 CAD each, including shipping, which isn't too bad. You might also see if you an get an equivalent plug from Bosch.
  20. Dave in Ireland
    Ireland
    I've been using NGKs for decades after more than one instance of dud Champion plugs new out of the box, which causes some head-scratching. Never had that with NGK. Otoh, I picked up some NOS Denso Twin-Tip recently at a very good price, and if they perform as well as the NGKs that were in it, I'll be happy enough.
