No juice at the coils
Discussion in 'XJ Technical Chat' started by xjchoppa, Sep 21, 2006.
  1. xjchoppa
    xjchoppa Member
    Oklahoma City, OK
    When I try to start my bike it will turn over but im not getting spark at the plugs... So I decided to put a test light to the coils and surprise surprise no juice at the coils...What are my possible culprits the coils are grounded and do check with the right resistance on the plug wire side and where they plug into the tci unit wires (I beleive)...
  2. BlueMaxim
    BlueMaxim Active Member
    Central Mississippi
    There are two checks for the coils with a multimeter. First remove the plug caps on the end of the plug wire and check resistance between the two wires. Make sure it is on the same coil. So that would be for coil 1 on the left side plug wires one and four. You should get close to 11K ohms. Then remove the connector on the coils and check the resistance between the 2 low tension wires going to the coil. You should get 3.5 ohms here.
  3. feelingold
    feelingold Member
    New Jersey
    All four plugs don’t get a spark? Hard to believe both coils went at once. Ok well easy stuff 1st. Make sure your engine kill switch is set to on. Check your side stand kill switch. After that maybe your TCI. If you want to check the static resistance of your coils the low voltage side is about 3 Ohms the high voltage side between plugs 1 & 4 for example is 11k Ohms with the plug caps off. A few guys here could go into even more detail so don’t be shy let us know what you find.
  4. xjchoppa
    xjchoppa Member
    Oklahoma City, OK
    The static resistance checks out good on the high voltage side and on the low voltage side..Maybe it is something with the kill switch..
  5. Robert
    Another possibility is the pickup coils fried. But I've not hear that happening too often so I'd lean toward the kill switch giving trouble. Ohm it out and be sure it is conducting correctly and isn't pinched to ground (common problem, get a lot of bikes cheap that way).
  6. BlueMaxim
    Central Mississippi
    Thanks for the correction. I was thinking about Dyna coils and knowing that they were 3 ohm I added .5 for the difference instead of subtracting. The standard low tension side is 2.5 with a + - 20% variance according to the XJCD.
  7. HooNz
    HooNz Member
    The key word here is NO volts at the coils , one could go checking resitance till the horse started drinking and its not going to help,
    Look at any switchs that supply 12v to the coils , and if no 12v is only when on the start position , start switch is wired wrong or its the wrong type of switch , as some switchs do switch off ign when turn to the start position [mostly deisals and magnito/cdi ingnitions], so you'll have to check.
  8. Nick
    Nick Member
    Vernon, BC Canada
    Here's what Yamaha says to troubleshoot the ignition system......
    Hope it helps!
  9. xjchoppa
    xjchoppa Member
    Oklahoma City, OK
    thanks for the replies im gonna work on her this weekend damn i love this website or more so its helpful members
