no rear running lights.
Discussion in 'XJ Technical Chat' started by midnightblu, Mar 10, 2009.
  1. midnightblu
    midnightblu Member
    Austin, TX
    i had running lights yesterday now today they are out. blinkers work brake running light and stop light all work and high and low beams. everything else works. when i bypass the curcut the lights work. anbody fixed this before?
  2. midnightblu
    midnightblu Member
    Austin, TX
    ok i went ahead and checked everything and found that on the running lamp circut i am only getting .22 volts where as on the front i get 12.75 my battery is charging since at 2000 rpm the voltage hits 13.8 on the battery.
  3. bill
    bill Active Member
    Raleigh, NC
    Could be a short - what do you mean by bypass the circuit?
  4. midnightblu
    midnightblu Member
    Austin, TX
    according to the wiring diagram they lead to the switch assembly on the solid blue wire. when connected there they have no issue. is it possible the signal relay isnt working right
  5. midnightblu
    midnightblu Member
    Austin, TX
    let me pose a different question.... who has working yellow running lights on the back of their maxim? ..... i wonder if i had a short and when i was doing some other repair i accidentally fixed a short.
  6. TheHound
    TheHound Active Member
    Scotia, NY
    I was thinking I don't have running lights, maybe the 700 is different.
    hehehehe
  7. wamaxim
    wamaxim Active Member
    Vancouver, USA
    No running lights on an 81 650 XJ. At least not on mine.
  8. alkasmeltzer
    alkasmeltzer Member
    Lincoln, NE
    No running lights on my 550 Maxim, either.
  9. 85MaximXX
    85MaximXX Member
    S.W. michigan
    no rear running lights on my 85 maximx X only fronts.
  10. 85MaximXX
    85MaximXX Member
    S.W. michigan
    there are also no wires to support the rer running lights on mine only two wires where the fronts have three.
  11. midnightblu
    midnightblu Member
    Austin, TX
    hmmm i must have fixed a short by accident
  12. flash1259
    flash1259 Member
    W.R. Wisconsin
    check the wire connections under the seat . I had the same problem after i painted my rear fender. reconnected it and bam its working again
  13. midnightblu
    midnightblu Member
    Austin, TX
    Uhhhh flash - everything is connected - i got a PM from SLKid his work all the time - the circut runs to the flasher relay i am back to wondering if this is a relay failure
  14. PainterD
    PainterD Active Member
    St. Cloud, Minnesota
    Sounds like a switch issue or a short in the wiring. There are NO rear running lights on these bikes if you have amber lenses. It's illegal to have amber running lights/brake lights in the rear. If you have three wires going to the front signals, then you have front running lights. You may want to check the kill switch contacts also. I had no signal lights yesterday untill I switched the kill switch off and on, so there may be an issue witht he contacts there?
  15. Robert
    There are no rear yellow running lights on our bikes, it is illegal in some areas (this is second-hand knowledge, anyone with greater experience please chime in).
  16. midnightblu
    midnightblu Member
    Austin, TX
    ya know now that ya'll both both said it i think you're right i think it is illegal to have them .... well then it has to be the accidental fix then. I'll have to ping SLKid about his.
    i though it was strange.... i am betting it was fixed by one of my standard practices which is to clean every contact you touch or have access to and to apply lithium greage to each contact to prevent corrosion and get a better contact. thats the only thing that it could have been.
