No spark, any suggestions?
Discussion in 'XJ Technical Chat' started by Tightmopedman9, Mar 22, 2008.
  1. Tightmopedman9
    Tightmopedman9 New Member
    Denver, CO
    My bike ran fine a week ago, I tried to start it today and I got no spark on all cylinders. I clean the connections to the TCI. Any advice on where to start checking, or how?
  2. RickCoMatic
    Fuse Panel.
    Safety Circuit Relay.
    Kill Switch.
    Ignition Switch.
  3. Travis-Mc
    Travis-Mc Member
    Hudson, WI
    My bet is corroded fuses... anyone want to put some money on this?
    Use a multimeter to check for voltage on the sides of the fuses.
  4. BlueMaxim
    BlueMaxim Active Member
    Central Mississippi
    Also check both grounds. One is from the battery to the engine block at the back of the case. The other is left side of TCI panel. If that is loose the TCI doesn't have a ground.
