no start in cold temps
Discussion in 'XJ Technical Chat' started by cobra, Feb 10, 2011.
  1. cobra
    cobra Member
    greenville sc
    my xj550 seca will not start in cold weather.it just spins over without even sputtering.when the temps are above 60 it starts just fine! what can i do to fix this.i have stage 3 jets,pod filters and straight exhaust.can i use starter fluid?
  2. mlew
    mlew Well-Known Member
    Apex, NC
    Take the carbs apart and clean the choke(fuel enrichment circuit). The little holes in the carb bowls that feed fuel to it are clogged. A occational use of starter fluid is OK but I would try not to use it on a regular basis.
  3. thecamelman79
    thecamelman79 Member
    Havelock, NC
    Also dont forget to check for a weak old battery. It might be fine in warm weather, but cranking amps can go down when it gets cold
