No start
Discussion in 'XJ Technical Chat' started by samjd07, May 24, 2011.
  1. samjd07
    samjd07 New Member
    I have battery voltage with new battery i just rebuilt starter i have spark good compression and i have fuel any ideas why i am still getting a long fast crank but no start. thanks
  2. SQLGuy
    SQLGuy Well-Known Member
    Well, if you're sure you have air, spark, fuel, and compression, there are really only three possibilities:
    1. Too much fuel and flooding
    - Are the plugs wet?
    2. Way too little fuel
    - Have you tried a good spray of starting fluid into the air box then seeing if it'll start and run for a couple of seconds?
    3. Timing
    - Any backfires? Any chance the 1/4 and 2/3 coil pickup wires, coil drive wires, or plug wires are swapped somewhere? Orange should go to 1/4; Grey to 2/3.
    By the way, I'm assuming you have a Yamaha XJ since you posted on this forum, but it's a good idea, and good form, to let people know what model and year bike you're asking about.
    Cheers,
    Paul
  3. samjd07
    samjd07 New Member
    the bike i am working on is 1982 yamaha 750 maxim. no backfires and the plugs are not wet but what happens sometimes which i just noticed this morning was carb number 3 dumps fuel out the air filter cone. but why would that make it not start? it should still fire right....
    thanks
  4. Robert
    You have a hung float valve. You need to pull your carbs and clean them meticulously. Check out how to clean your carbs and the whole nine yards by Rick-O-Matic.
  5. bigfitz52
    -Is this bike equipped with "pod" filters rather than the stock airbox?
    -Has the exhaust system been modified?
    -Has it ever run, that you've seen?
    -Have you recently performed some modifications?
    The more info the better; you're not giving us much to go on.
