non starter
Discussion in 'XJ Technical Chat' started by putz, Oct 20, 2012.
  1. putz
    putz New Member
    Rochester , England
    hi, my xj600 just will not start , iam using starter fluid and it just pops a bit. There is a spark on all 4 plugs and fuel is gettingthrough, also tried another set of carbs which were working ok. The exhaust system is off at the moment could this be not helping. thanks :cry:
  2. livingdeadlyxj650
    livingdeadlyxj650 Member
    kimberling city MO.
    check your battery. make sure ur terminals are clean. i believe these batteries shouldnt drop below 9 v during cranking. and be right around 12.8 with no load.
  3. bigfitz52
    Don't fire it up with no exhaust system; you could very quickly say bye-bye to an exhaust valve or two.
  4. mlew
    mlew Well-Known Member
    Apex, NC
    Have you done a compression test ?
  5. putz
    putz New Member
    Rochester , England
    cheers guys, will put the exhaust system back on before i try to start it again, hope its ok been trying to start it for days with it off. Have not done a compression test and was thinking if exhaust off it would lower compression. Idid notice the plugs were black , not oily , just turned black and spark runs up and down electrode sometimes and not across gap?.
  6. mlew
    Apex, NC
    Black and sooty plugs will not fire properly, clean or replace them. The black is carbon and will " short out the plug" causing it not to fire.
    Next is to look into the carbs to find out what the problem is.
  7. putz
    putz New Member
    Rochester , England
    cheers will clean the plugs and give it a try, when the exhaust is on.
  8. markie
    markie Member
    Suffolk, England
    Sent you a pm - if you cut and reconnected the pickup wires, they might be the wrong way round.
