NOOOOOOOOO!
Discussion in 'XJ Technical Chat' started by Tweezer, Apr 6, 2008.
  1. Tweezer
    Tweezer New Member
    Lawrenceburg, Indiana
    Okay, so I just busted one of the posts off where the float assembly mounts to the carb. Not good. So my first thought was to drill a hole in the busted piece and the remaining section and use jb weld in the holes to hold them together. after assembly of course. Anyone got any better ideas? Not sure if the jb is stable when submerged in gasoline.
  2. chacal
    I have complete used carb assemblies (bare or dressed) available if and when it comes to that. PM me for prices, and let me know which carb body it is (all four are different).
  3. Ace_Frehley
    Ace_Frehley Member
    NS Canada
    I haven't tried it myself, but I do belief others have used JB Weld with success for just such a problem
  4. TECHLINETOM
    TECHLINETOM Member
    Deerfield OH
    JB Weld is fine.
  5. Tweezer
    Tweezer New Member
    thanks guys
  6. wink1018
    wink1018 Active Member
    Muncy, Pennsylvania
    Or just take them to your local machine shop and have them weld that aluminum.
  7. tjdude
    tjdude Member
    lubbock tx
    na jb weld it. I did it to a dirtbike and it was a good fix for me.
  8. fonz
    fonz Member
    Philly burbs
    havent had my carbs apart since but I used JB Weld for the exact same thing. no problems.
  9. Lanmanager
    Lanmanager New Member
    Atlanta, Ga
    Hey hey is there any problem that beer and JB weld can't fix?
  10. RickCoMatic
    I wouldn't recommend anything short of finding a replacement Carb Body with a non-broken Post.
    I wouldn't trust anything short of doing it right!
    The geometry of the Float Hinge is Critical.
    If you are off by a little bit ... you'll hang-up a Float and flood.
    The recommendation is to find a used Body.
    Strip it clean.
    Everything ... including all the Air Jets and Metering.
    Swap all of your Parts on to the replacement Body.
    (Before you extract the ztwo air jets found below the cover plate (optional) on the top-end of the Carb Body ... Note their Position.
    The Haynes Manual is misprinted and reverses the labeling.
    The Air Jet with the Larger Metering Port is PILOT AIR
    The Air Jet with the Smaller Metering Port is MAIN AIR>
