Number 4 is alive (ADDED RACK)
Discussion in 'XJ Technical Chat' started by FlyGp, Dec 19, 2012.
  1. FlyGp
    FlyGp Member
    Michigan
    Number 4 is alive
    Click on the picture to play the video….(copyright FlyGp3D 2012)
    This is a non-rendered screen grab so quality is low, but comments / feedback / criticisms are appreciated as usual.
    FlyGp
  2. CaptNemo
    CaptNemo Member
    Reno
    Re: Number 4 is alive
    Zestfully clean!
  3. joeperezis
    joeperezis Member
    Hudson, Illinois
    Very niiiiiiiiiice! Love the detail, especially around the pilot screw! Nice job FlyGp!
  4. mook1al
    mook1al Member
    Talladega, AL
    I thought there were 3 holes in the plot fuel/air chamber...are one of the holes off set from the cross section?
  5. KrS14
    KrS14 Active Member
    St Marys, Ontario
    I'm pretty sure, there's 3 holes in a triangular config. The one should be centered, the other two are on the sides and closer to the needle.
  6. livingdeadlyxj650
    livingdeadlyxj650 Member
    kimberling city MO.
    Agreed! And not to b nit picky but perhaps the sync screw should be touching its spring loaded stop. Mine do anyways. Even with the screw backed out. But pristine job otherwizze! I wish I had the ability to do something of this sorts.
  7. razz1969
    razz1969 Active Member
    Cleveland, Tx
    Beautiful job!!!!! What format is that? Is there a way I can get the file from you? Is there a way to see the enrichment circuit?
  8. FlyGp
    FlyGp Member
    Michigan
    Power is out at our house do to the winter storm. I will respond and provide more information about the video when power is restored and i can use the computer VS the phone.
    FlyGp
  9. FlyGp
    FlyGp Member
    Michigan
    Very observant, yes there are three holes in the pilot circuit. The hole that the pilot needle interfaces with and two bypass holes obscured by the throttle disk.
    The section view in the video is cut exactly on the centerline, the two bypass holes are slightly off center so they are not clear in the section view.
    The gap between the throttle shaft adjustment screw and its spring loaded opposing pad is intentional. When the rack is assembled the interfacing next linkage component fits between the adjustment screw and the spring loaded pad. This gap would be closed by the spring only when the rack is split.
    Below I have included a picture of the three pilot circuit holes highlighted in a contrasting color. I have also included a photo showing the adjustment screw and spring pad showing the interconnecting next link that creates the gap seen in the 3D model.
    Thanks for the excellent observations and comments, I am not offended by the nit picking as you say, the exchange if observations only makes the project better in the long run and I truly appreciate all feedback.
    FlyGp
  10. osprey1000
    osprey1000 Member
    Annapolis, MD
    Fly that is some amazing work. All the work I have seen that you have done so far is just amazing. Keep it up, I can't wait to see the finished product.
  11. tabaka45
    tabaka45 Well-Known Member
    Brunswick, Georgia
    Now, that's just darn good!
  12. FlyGp
    FlyGp Member
    Michigan
    It was a productive week on the project; I nearly finished the complete carburetor rack. Below is a test rendering, if you see any errors let me know.
    FlyGp
  13. Maxim-X
    Maxim-X Well-Known Member
    London Ontario Canada
    Nice touch with the butterfly screws set at slightly different clocking. Now, for the nit picking.....you need to add just a little dirt to make them look really real. :twisted: :twisted:
    Exemplary work as usual Fly!
  14. sirMikel
    sirMikel New Member
    great work there fly! love the detail!!
  15. livingdeadlyxj650
    kimberling city MO.
    my god beautiful. only thing i noticed is the spotting by the tab that the enrichment rod runs through. its the only thing that doesent look as gorgeous as the rest. fantastic work though bud. :D
  16. osprey1000
    osprey1000 Member
    Annapolis, MD
    Can't really see from this angle but did you include the holders for the clutch cable and vacuum line? Beyond that absolutely amazing job!
