oil consumption
Discussion in 'XJ Technical Chat' started by Schaf1cm, May 30, 2007.
  1. Schaf1cm
    Schaf1cm New Member
    Central Michigan
    So I went on a long-ish ride last thursday (about 130) miles, it was hot out (over 80 degrees) and i spent aobut 20 minutes at speeds between 80-105 mph, with most ofo the other time spent around 70. I havnt ever had an oil leaking problem or really noticeable oil consumption, but when i got to where i was going i was quite low on oil. Now i have done this trip a few times without checking the oil so this may be a cumulative effect, but could it be a combination of factors that (Heat?) that caused the excessive oil burnoff?
  2. Fraps
    Fraps Member
    Kitchener, Ontario, Canada
    Did you check the oil right after the ride or did you let the bike sit (read: let the oil settle) first?
  3. Schaf1cm
    Schaf1cm New Member
    Central Michigan
    I checked it about 4 days later.
  4. Gene
    Gene Member
    Madrid, Spain
    Add oil and check the difference after one trip.
    If you can't notice a big difference you are probably ok. It is normal to burn some.
    If after 130 miles at 80 degrees you are missing a lot of oil, then I would worry.
