oil cooler
Discussion in 'Hangout Lounge' started by darkangel, Jul 8, 2008.
  1. darkangel
    darkangel Member
    Liberal, Ks
    where can I find a oil cooler for a 83 maxim 750
  2. darkangel
    darkangel Member
    Liberal, Ks
    Ok does anyone know?
  3. one2dmax
    one2dmax Member
    Find one from a seca turbo being parted out. You'll need to get the full adapter, hoses, and through bolt.
    Sean
  4. RickCoMatic
    The Oil Cooler I put on my Max-750 came off a Seca900 Parts Bike.
    Everything fit perfectly to the Oil Filter Housing and the Cooler and Lines don't need too much Fabrication to make them fit.
    I had to move my stock horns and use the captives for bolting-up the lower-end of the cooler.
    I put a thick rubber bushing in the Braze-on that's already in place on the Max.
    You have to lower the Cooler about 12mm to make sure the tree don't come into contact with the top of it when the steering goes lock-to-lock.
    Other than some simple stuff ... it was pretty-much a bolt-on and go.
  5. darkangel
    darkangel Member
    Liberal, Ks
  6. RickCoMatic
    Before you buy that thing .... ask the seller you manufactures it and if all the parts you need come with it.
    The OEM one comes with a center securing "Flange-Bolt" that secures the fixture to the block and is internally threaded to accept the Oil Filter Bolt.
    Who makes it?
    What else do you need?
  7. wizard
    is your oil overheating, then, dark one?
  8. darkangel
    darkangel Member
    Liberal, Ks
    yeah a little, My engine has open exhaust and I have a cold air intake on my carbs...and the engine just seems to bake the oil a little.
  9. RickCoMatic
    You're not running too Lean and getting into an Overheating situation, are you?
    Examine the Spark Plugs and see what they say about the Mixtures your are running.
    If you are running it critically lean, the oil cooler isn't going to be enough cooling-off to offset the Lean condition.
  10. darkangel
    darkangel Member
    Liberal, Ks
    the engine doesn't seem to be running lean, but then again...I need to test and see.
  11. grimreaper169
    grimreaper169 Member
    Mims,Fl.
    They tell me that synthetic oil will reduce the temp. I run amosoil in my 750. Just sayin.
  12. wizard
    don't think it's good for the clutch though.
  13. RickCoMatic
    There are a few synthetic oils designed to be used in wet clutch motorcycle applications.
    The synthetic oil will NOT reduce the operating temperature.
    The synthetic oil will resists breaking-down as rapidly as a conventional oil when exposed to high heat.
    Be sure the oil you select if free of friction reducers.
    All you have to do to determine if you bike is running critically lean is examine the Plugs.
    If they are clean
    If the Ceramic surrounding the Center Electrode shows evidence of hairline cracks. (Use a magnifying glass.)
    If you have to add oil to the bike to make-up for what is being burned as a source of fuel from running too lean ...
    Adjust the Mixture to increase the supplemental fuel from the Pilot Mixture Screws until the critically lean situation is relieved.
    If the Lean condition cannot be adjusted-out with Pilot Mixture Screw adjustment ...
    Re-Jet -- Up the Pilot FUEL Jet a size.
