Oil filter bolt
Discussion in 'XJ Technical Chat' started by jeffcoslacker, Oct 2, 2010.
  1. jeffcoslacker
    jeffcoslacker Member
    SW MO
    Hopefully you guys will tell me of some more reasonable way to fix this.
    That head is all chewed up...been hammering a 6 sided 7/16" socket onto it for years to change the filter, but every time I swear it's gonna be the last go-round for that bolt. One of these days it will become impossible to remove, it seems.
    I thought I looked it up once before and was like $62 or something. FAT CHANCE!
    If the cover was steel, I'd weld something to it for a better grip. I doubt a brazed nut would be strong enough though....
  2. bigfitz52
    From Yamaha maybe, although that sounds steep, maybe Bike Bandit.
    from chacal's catalog:
    HCP1067 OEM oil filter PRESSURE RELIEF BYPASS VALVE & COVER MOUNTING BOLT, bright plated finish, small 12mm head, for all XJ550, XJ650, XJ700, XJ750, and XJ900RK models. NOTE: All Midnight Maxim and XJ900RK models used this bolt, but it had a black finish on the head.
    $ 37.95
    HCP270 Aftermarket oil filter PRESSURE RELIEF BYPASS VALVE & COVER MOUNTING BOLT, bright plated finish, large 17mm head, fits all XJ550, XJ650, XJ700, XJ750, and XJ900RK models. NOTE: All Midnight Maxim and XJ900RK models used this bolt, but it had a black finish on the head.
    $ 14.95
    I recommend the aftermarket one with the larger head. The torque spec is cast into the cover, by the way: 1.5Kg-m which is only 11 ft/lbs.
  3. Ravenz07
    Ravenz07 Member
    Really not bad prices. You can occasionally find one on eBay as well. Good luck!
  4. ZaGhost
    ZaGhost Member
    Dartmouth, Nova Scotia
    I got the EMGO after market replacement, much larger head, for $16 Cdn
  5. SilverSeca
    SilverSeca Member
    Lancaster PA, USA
    There's a bunch of them on ebay, but if you have some time and little coin...file the bolt head flat during your next change. File all sides to square them off...maybe to a 1/4 sized bolt...should get you another 5 oil changes...and try to keep the hammer in the toolbox. :wink:
