Oil Filter case stuck
Discussion in 'XJ Technical Chat' started by Johnny And June, Sep 28, 2015.
  1. Johnny And June
    Johnny And June Member
    Mandeville, LA
    Ok, so My oil filter case's bolt is stripped. I have used a dremel to cut a notch in the bolt, but even with my man-power, the use of a drill, and my father, we cannot seem to get the bolt to budge. any ideas?
  2. Johnny And June
    Mandeville, LA
    should clarify, I'm using a flathead screwdriver and drillbit
  3. wizard
    See what looks like a washer under the nut, is in fact, part off the nut, get a long, thin cold chisel & knock it round.
    Alan63 likes this.
  4. XJ550H
    you been working this for a while
    grind down the remaining bolt head carefully untill the washer base of the head turns blue and thin then it will fall off then you will be able to pull off the case and remove the bolt shaft. go carfully, there is a thread somewhere where someone else does this I will look for it.
    you could drill into it and use an easy out but if it snaps your problem gets harder
    read this thread
    http://www.xjbikes.com/forums/threads/im-back-and-my-f-in-oil-filter-is-stuck.55021/
  5. Johnny And June
    Mandeville, LA
    i've been away from the bike for a while and finally got the time to start working on it again, so more like finally getting back to it.
  6. Johnny And June
    Mandeville, LA
    What do I do from here? Also, I know, PO put it on upside down
  7. Johnny And June
    Mandeville, LA
    grind further?
  8. Ross1bd
    Ross1bd Member
    Syracuse, NY
    Just to clarify, was the head of the bolt rounded off or are the threads stripped?
  9. MattiThundrrr
    MattiThundrrr Not a guru
    America's friendly hat
    Since you've pretty much destroyed the bolt, you may wanna check out the spin-on filter conversion that xj4ever sells. Another expense, but you won't have this problem at the next oil change.
  10. Johnny And June
    Mandeville, LA
    I've got a back up oil filter case to use. But I will keep the spin on in mind for the future.
    Ross: The bolt was rounded off
  11. XJ550H
  12. XJ550H
    if you have a back up case go with grinding .
  13. MattiThundrrr
    Do you have a back up bolt? That's what got demolished! Must be nice to have spares. I need a parts hoard!
  14. XJ550H
    :cool:
  15. Alan63
    Alan63 Active Member
    Saskatoon,sask. Canada
    Always works for me
  16. Johnny And June
    Mandeville, LA
    Okay, did a bit more grinding and got the case loose. I can see the broken crease of the bolt and the front of the case. It wiggles and spins, but won't slide off yet.
  17. hogfiddles
    Careful grinding/dremel-ing to get the burr off so you can slide the cover off. I've done this a lot.....
  18. hogfiddles
    I have a parts hoard....... Lol
  19. MattiThundrrr
    It was your stash that I was thinking of, Dave!
  20. Johnny And June
    Mandeville, LA
    Alright I got it off! Now to work that stupid drain plug right under it. Seems the PO really refused to use anti seize
