Oil Filter Change problem
Discussion in 'XJ Technical Chat' started by Bruceedward, Aug 4, 2017.
  1. Bruceedward
    Bruceedward New Member
    Excelsior Springs, MO.
    I have an 82' xj750rj Seca; first time changing the oil filter (new bike for me)....took off the housing and removed the stock filter -to replace with a new stock filter; but I didn"t pay attention to whether the concave side of the filter (with the metal washer) goes towards or away from the engine. I know, dumb mistake, happens all the time when you are 69 years old. Thanks for any helpful input.
    flat side towards motor . the steel washer is for the spring that goes over the bolt
    I think you will find the metal washer is not part of the filter just kinda stuck to it
    #8 is the spring #7 washer and you do need the spring
    SPRING, COMPRESSION
    90501-20422-00
  3. Bruceedward
    Thank you XJ550H ... the added diagram is exactly what I needed...it's hell getting old: enjoy your youth.
    Bruce
  4. cgutz
    cgutz Well-Known Member
    SE South Dakota
    LOL, I've had my bike since it was brand new, probably close to 50 oil changes. I still have to look at the diagram to get it right!
    Rooster53 and Stumplifter like this.
