opinions on torque wrenches
Discussion in 'Hangout Lounge' started by saftie, Jun 1, 2015.
  1. saftie
    New York, NY
    Hey,
    What torque wrenches are you guys using? Brand/model?
    Mine broke and I need a new one.
    thanks,
    Gabor
  2. Stumplifter
    Stumplifter Well-Known Member
    near Irma, WI
    Craftsman Beam and a Harbor Freight (?) clicker for smaller setting (in/ lbs).
    No idea what model numbers and too lazy to go look.
    The clicker one gets set to zero when not used AND gets exercised prior to use (got burned once and had to deal with a sheared bolt on my YJ Wrangler).
    Toomanybikes likes this.
  3. Toomanybikes
    Tsawwassen bc
    Stumplifter is spot on. great tools get you great results. Consider the cost in time and frustration of broken bolts. Go with name brand like craftsman snap on etc.
  4. saftie
    New York, NY
    Thanks. Yes, I don't mind spending a little more to get better tools. I learned that a while ago
  5. Ribo
    Ribo Prefectionist
    Yep - happened to me too - sometimes even a decent torque wrench can lock-up when on the shelf.
    Before you use it always put a nut in a vice and make sure it works as expected. Note I said "a" nut and not "your" nut - this is crucial. :)
    Stumplifter likes this.
  6. jmilliken
    jmilliken Well-Known Member
    Dillsburg, PA
    I just use an inexpensive harbor freight model. Works perfectly fine for the once or twice a month I use it....
