paint on tires
Discussion in 'Hangout Lounge' started by Impulse2k1, Apr 18, 2007.
  1. Impulse2k1
    Impulse2k1 Member
    Illinois
    I was painting my front rim and got some over spray on the tire, is there a way that I could get it off? I was thinking of using carb cleaner any other suggestions?
  2. iwingameover
    iwingameover Active Member
    NO! Carb cleaner is not a good idea. It'll dry out the rubber. Not sure what is a good idea but carb clean is not.
  3. Impulse2k1
    Impulse2k1 Member
    Illinois
    hmmm........makes sense that never realy crossed my mind. I tried rubbing some of it away with armor and it didn't seem to work that well
  4. Ace_Frehley
    Ace_Frehley Member
    NS Canada
    Wait for the rims to dry and set up well ( couple of days ) then use spray nine or super clean, some type of strong cleaner and it should come off
  5. Robert
    I'd suggest you try WD-40.
    Failing that, and i'm thinking it won't, try Goof-Off citrus.
  6. MiCarl
    120 grit sandpaper.
    Then 400 wet. Followed by 800, 1000 and then 1200 with armor all. Boy will those sidewalls look good.
    :D
  7. Robert
    He he he he, bet the reflection on the walls will blind the public! Watch out!
  8. RickCoMatic
    A dampened rag with lacquer thinner ... done!
  9. kevineleven
    kevineleven Member
    Columbus, Ohio
    My thoughts exactly, rick.
  10. beanflicker_98
    beanflicker_98 Member
    east petersburg pa
    dampen rag with carb cleaner.
  11. Polock
    brake fluid
  12. tewlman
    tewlman Member
    Columbus Ohio
    try a mr clean magic eraser
  13. eatatjoz
    eatatjoz Member
    Mayflower, Ar
    I want some of these paint-on-tires! I'll take a can of radial please.
    I can't help, but I couldn't resist either.
