Peep this my XJ brothers, rear rim on the front.
Discussion in 'XJ Modifications' started by XVFinishes, Nov 29, 2009.
  1. XVFinishes
    XVFinishes Member
    Toledo, Ohio
  2. streetbrawler750
    streetbrawler750 Member
    Minnesota
    That is awesome I am wanting it bad!
  3. schooter
    whats the benefit?
  4. danno
    danno Member
    Union Springs,New York
    To make people ask why. If that is a 16" rim,I am guessing a big fat sneaker will be hugging this wheel,and it I bet it will look awesome! Likely the handling will suffer ( not much ),but the cool factor could be through the roof. Pity the fool that doesn't update us on his progress!
  5. Hillsy
    Hillsy Member
    Form over function. The flat-tracker look.
  6. MaximumX
    MaximumX Member
    Ottawa, Canada
    I went a different route to fit my 16" sneaker and it's perfectly functional as well as having "form". Even has dual rotors...
  7. dakine_surf
    dakine_surf New Member
    Yeah I have seen this done on the virago Zero Tribute bike. Someone correct me if I am wrong, but I thought it is actually 18in front and rear wheels... very cool indeed. Handling might suffer a little, but it looks great. I would love to do this if it could be done to a 750 seca. Anyone know if it is possible?
  8. dfknoll
    dfknoll Member
    Frankenmuth, Michigan
    That looks big and nasty! I love it. lol
  9. vintagerice
    vintagerice Member
    New Hampshire
    I am with schoot.. The reason for this is why???
    Rob
  10. dakine_surf
    Purely aesthetics... some don't like the look, but i personally love the look of the same tire front and rear. Especially when the front is lowered just a bit.
    But then again, it does slow you down in the corners, and the big front wheel can be felt around town a bit more.
    I would love to see someone do it with the dual front disks on a seca.
  11. the_namdeeW
    the_namdeeW New Member
    Bay Area, CA
  12. bigfitz52
    does the term "unsprung weight" mean anything to you?
    There is a REASON bikes don't come with huge heavy front wheels.
  13. streetbrawler750
    Minnesota
  14. seaguy
    seaguy Member
    Coastal,AL
    I was waiting for someone to mention EXILE CYCLES. I think he revived the phat front from the 50's.
  15. streetbrawler750
    Minnesota
    I think they are great, but I know it is not a taste that all enjoy.
  16. PainterD
    PainterD Active Member
    St. Cloud, Minnesota
    I like the fat front tire look with no fender. I'm going with the widest tire I can mount on it when I get new rubber. Looks great!
  17. seaguy
    seaguy Member
    Coastal,AL
    Yeah I like that look. Think I would dish pan that rear wheel since they don't match. Might look even better. Hey painter why don't you cut the spokes on a rear and front wheel and weld the rear rim to the front hub spokes. should work if laid out good. Wish I had more parts to play with. That cast is a pain to weld though. Be brave my man and post the pics before you try it out. :wink:
  18. Hillsy
    Hillsy Member
    I'm not an alloy welder, but aren't there structural integrity issues with welding cast alloy?
  19. seaguy
    seaguy Member
    Coastal,AL
    People do it so that's why i told him to be brave but post pics before that first ride. It's possible that a painter don't weld too. Just running my big mouth there Hill.
  20. HogWild
    HogWild New Member
    Jonesboro Arkansas
    This looks awesome! I have a XJ 550 and I can't decide whether to keep her bone stock looking or modify like crazy. This is sweet though.
  21. PainterD
    I do weld (have for 30 years) just not aluminum or magnesium. Anything's possible if you want to do it bad enough I guess. I just want to go with the widest tire I can fit on the stock rim. The fender and mounts would be the only thing holding me back from going as wide as the rear. But the fender mounts can be cut off, sanded down and polished to look like they were never there, so it's doable.
  22. 16ozbud
    16ozbud Member
    louisiana
    I've been looking into getting something a little wider on the front of my bike, preferrably shorter also, like the back tire. Painter is right on the money with the fender mounts. I'm not running any instruments so I don't need the odometer gear. That should allow for a little more clearance to get something wider. I've even been looking at other triple tree setups. That's gonna take a lot of figgerin' and cypherin'. That could take awhile.
  23. streetbrawler750
    Minnesota
    Actually a 130/90 16 will fit between the fender mounts with no modification.The fender will not fit though.
  24. XJ70086
    XJ70086 Member
    New to the forum and doing the vulture thing on a local XJ700 maxim from 1986 for sale. What are the widest tires ( RADIAL, not bias ) that will fit on an XJ700 standard rim? Thanks.
    Vince
  25. Swissjon
    Swissjon Member
    LoL... Nice... Not my style but nice..
  26. koolaid5
    koolaid5 Member
    Chambersburg, PA
    keep posting up the fat fronts. I love it :D
  27. XVFinishes
    XVFinishes Member
    Toledo, Ohio
    Due to forced changes in the Virago Tech Forum non members will not be able to access to links in the forum.
    But you can see the 2 parts thread about it here
    Rear Rim on the Front Part I
    Rear Rim on the Front Part II
    http://viragotech.com/newtech/index.html
  28. non_quotidiun
    non_quotidiun Member
    South Western Australia
    Must be so if he got a flat front tyre he could change it out using the back one....yep that'd be it..
  29. koolaid5
    koolaid5 Member
    Chambersburg, PA
    I love exile cycles. I'd like to do the fat front on my '83 XJ 750, but I'd want to go with the dual disc set up and not sure how to do that.
  30. koolaid5
    koolaid5 Member
    Chambersburg, PA
    speaking of which....this is one of my favorites. Where is the throttle though? I LOVE how clean the bars are. Looks awesome
  31. streetbrawler750
    Minnesota
    Just look at page 1 of this thread for a dual disk 130/90 16 set up!
  32. theadbrewer
    theadbrewer Member
    Roseville MN
    That looks cool I like very much
  33. koolaid5
    koolaid5 Member
    Chambersburg, PA
    Yeah, I saw your post on page 1 brawler. I don't know what wheel that is or how you did it though. I'm not sure I dig having a different wheel on the front than the back either though.
  34. roddyxj
    roddyxj Member
    Miami
    Check this out look at some fATTY'S ON THE FRONT... i did thought about it bu didnt think i would work.... look at the pict below....
    http://www.zero-eng.com/
  35. FABFABINC
    FABFABINC Member
    Montreal canada
    This is my fat front tire lolol
  36. streetmaster
    streetmaster Member
    So how does one obtain the center axle plate to fit the rear wheel up front?
  37. streetbrawler750
    Minnesota
    That is not my bike, and I know nothing about the bike. Just re posted a guys post.
    As far as obtaining the axle plate and kit, e mail, racer6692@yahoo.com, guys name is Matt, thats where I got mine and am very happy with it.
  38. BillB
    BillB Active Member
    Tulsa Oklahoma
    can anyone say head turner?
  39. hogfiddles
    Yeah, I turn my head the other way. I think it looks ridiculous. Personal taste, of course. I like the look of the skinny larger diameter front tires.
    dave
