Petcock Leak
Discussion in 'XJ Technical Chat' started by adr3naline, Jun 20, 2012.
  1. adr3naline
    adr3naline Member
    So I'm considering getting a petcock kit for my 82 xj550. It leaks out of the bottom gasket pretty bad. Would a rebuild kit be sufficient for these old petcocks, or do you recommend something else? Could I get away with just getting the bottom gasket?
  2. adr3naline
    adr3naline Member
    Actually I'm not even seeing a gasket on eBay in that same shape... It has 2 screws on opposite corners. Could I just get some liquid gasket?
  3. fintip
    fintip Member
    Austin
    The rebuild kit is about $30; there's also a (non-vacuum operated, completely manual) new petcock available on ebay for that price. Some people have been very meticulous and still not been able to repair their petcock, so given that I don't have much experience machining parts, I put my original petcock aside to rebuild another day in the distant future and went with a manual one from ebay for the moment.
    Make sure to turn it off when you stop if you go that route, don't want to accidentally get gas in your oil one day...
  4. bigfitz52
    If you rebuild it, do it right if you want it to work right: http://xjbikes.com/Forums/viewtopic/t=25058.html
    XJ4Ever has all of the necessary and correct parts. If you follow the instructions carefully you can successfully rebuild it, provided the valve seat isn't pitted beyond polishing out. That's covered in the linked article.
  5. adr3naline
    adr3naline Member
    I just ordered the gasket from XJ4Ever... he was great to work with on the order.
    So is that gasket a felt style? Is there a good recommendation for installation, or is it just sandwich and hope it works? Thanks!
  6. bigfitz52
  7. adr3naline
    adr3naline Member
    I had read the entire article, before you posted it again. All it says in reference to that gasket is "For the petcocks so equipped, fit a new output pipe flange gasket." All I wanted to know is if there were special considerations from everyone who have dealt with these bikes/petcocks before. You must be sick of anyone who finds the search feature on this forum difficult to find specific answers. I'm sorry to have asked such an apparent common question. GEEZ!
  8. trickedout420
    trickedout420 Member
    Greenwood MO
    i ordered a rebuild kit for mine off of ebay before i took it apart...and well needless to say i just ordered a deluxe petcock from chacal..because mine wasnt rebuildable
  9. bigfitz52
    It says "fit a new gasket." The pictures illustrate said gasket, and clearly show it in position. Then it says "install the output flange" and the picture shows it installed. If there were any "special considerations" they would have been mentioned. I'm sorry if I couldn't see how I could have possibly made it any clearer. What exactly did I leave out? Anyone???
    I'm only "sick of" people who can't or won't follow advice given. That doesn't seem to be your issue; it simply appeared from your questions that you hadn't actually read the article. My apologies.
  10. tabaka45
    tabaka45 Well-Known Member
    Brunswick, Georgia
    take my advice--learned the hard way--follow fitz's instructions to the letter, and the rebuild kit will work. Cleanliness and polishing is critical. Do it right the first time.
  11. bigfitz52
    Hey man I try-- you have no idea how many hours and how many photos (that are never seen) go into my stuff. Thanks for the good word.
  12. adr3naline
    adr3naline Member
    And yes, your step by step guide was very thorough and well documented and photographed. Thank you for the resource and shared experience.
