Petcock position question...
Discussion in 'XJ Technical Chat' started by XJ1100, Apr 17, 2007.
  1. XJ1100
    XJ1100 Member
    Duluth, MN
    Okay, I'm going to get a reputation for asking stupid noob questions...
    1. Which part of the petcock indicator "indicates" it's position? Does the handle pointed at "RES" mean it's on reserve or the rounded part?
    2. I read somewhere that if the bike has been sitting for more than a few days since it last ran that it should be switched to "PRI" (prime) for a second or so to fill the carbs before you hit the starter. True?
    3. If it's left on "PRI" when it's parked, fuel will continue to drip out of the air filters? True?
    Every site has to have "one of those guys" that asks the dumb questions. I elect myself!
  2. Ace_Frehley
    Ace_Frehley Member
    NS Canada
    1) the end of the handle points to the position ( on my 650 it has a small arrow on the end, gotta look close though)
    2) PRI is only used to refill the carb bowls, I've had my bike sit for days, even a week and not had to use PRI, some others do. SO its really your choice.
    3) If left on PRI, AND your float needle or floats stick, then you can flood the crankcase or the airbox. If your floats are fine, then, in theory, you could leave it on PRi and have no problems, but thats a big IF. Thus, save thing is to NEVER leave your bike sitting on PRI.
    Hope it helps, and P.s. they're not dumb questions, everybody has to learn and the only way is to ask
  3. MiCarl
    Another problem with leaving on PRI.... If you run it out of gas on PRI the reserve is gone too.
  4. XJ1100
    XJ1100 Member
    Duluth, MN
    All good answers. Thanks guys. I can always count you this site.
  5. mr_ex
    mr_ex Member
    maine usa
    ill ask another dumb question :D
    can the gas be turned off????
    i have yet to own a bike with an off position.
    shure would make takin the tank off a lot less messy :cry:
  6. BlueMaxim
    BlueMaxim Active Member
    Central Mississippi
    The fuel should be off when the bike is not running and the petcock is set to either the "On" or "res" position. The petcock is a vacuum actuated unit. The second line coming off the petcock is the vacuum line. It goes to the #3 intake manifold. When the bike is running the intake is pulling vacuum. This pulls on the rubber diaphraghm inside the petcock which pulls a spring loaded plunger with an oring at it's end off of a seat, thus allowing fuel to flow. Turn the bike off and the vacuum stops, thus allowing the spring on the plunger to push the oring back into it's seat, thus stopping the fow of fuel. In the "pri" postion the plunger is pushed back unseating the plunger/oring and allowing fuel to flow without the need for vacuum.
    If you disconnect your fuel line from the petcock in either the "on" or "res" position to remove your tank while the engine is off, the fuel should not flow. If it does then the petcock needs repairing. This could be as simple as replacing the oring or stretching the spring so it pushes the oring back in with enough pressure. It may also require replacing the rubber diaphraghm which could be torn. If it is torn it will allow fuel to flow in any position.
  7. mr_ex
    mr_ex Member
    maine usa
    ty blue maxim good info
    jeez i think im gonna like it here
  8. XJ1100
    XJ1100 Member
    Duluth, MN
    Are you trying to challenge my position of "asks dumb questions guy"???
  9. mr_ex
    mr_ex Member
    maine usa
    oh not at all......but i fit in well with these kinda threads :lol: :lol: :lol:
  10. Robert
    No such thing as a dumb question, only dumb answers. Ask away but do try the search function to see if the question has been answered already. Of course it is nice to have a rehash of an old topic, brings new ideas in.
  11. alFrumpus
    alFrumpus Member
    Saskatoon, SK, Canada
    ...Another engine-dumb guy here. Thanks for a greater understanding of my puzzling petcock.
    (**EDIT: See, my idea here is that if I find any post which helps me out, to add a comment or thank-you, so that if I need a refresher course, I don't have to use the forum's search engine - I'll only have to find my own posts.)
  12. Scrape
    Scrape Member
    Creedmoor, North Carolina
    It's great for the post count too! err ahh..remind me to be more polite in the future. :idea:
  13. alFrumpus
    alFrumpus Member
    (Good point - that IS the main downside of my idea: I get to look like a poser who cares about racking up a postcount. BTW, sweet looking bike: http://xjbikes.com/Forums/viewtopic/t=4239.html :) )
  14. Tomh
    Tomh New Member
    Charlotte, NC
    My 82 xj1100 has an "off" position as well as on, reserve and prime.
  15. BillB
    BillB Active Member
    Tulsa Oklahoma
    I changed mine to a manual for peace of mind and it was $15. Mostly because it was $15.
  16. RickCoMatic
    The XJ1100 has a completely SEPARATE Vacuum Operated Fuel Shut-off System that functions to regulate the Fuel Flow from the Petcocks.
    There's also a good deal of PLUMBING that need to be checked for Kinks and proper routing.
    The Fuel EXITS the Petcocks and Flows to the VACUUM Valve which Opens and Closes from Manifold Vacuum.
  17. 81maxim_83
    81maxim_83 New Member
    welcome nc
    thats great info I had no clue and was running my 82 750 on pri till it ran off of gas and i thought something was really wrong with it. Thanks for the info..
  18. bigfitz52
    Direct answers to your not-that-dumb questions:
    1. The "arrow" is on the handle, so you point the handle at your "selection."
    2. Not a bad idea.
    3. Shouldn't. If this happens, it indicates a carburetor float valve problem or mis-adjustment. The floats should be able to shut off fuel even if the petcock is on PRI.
